- Dec 23, 2012
So to start out I've been searching forums and everywhere else since BEFORE I bought my FX-4300, and I still can't find any really good posts on overclocking this particular CPU. I've seen and read tons of 6300 and 83xx posts, and even more 41xx/61xx/81xx posts.
Part of this is certainly due to the Piledriver CPU's still being new, and part of this has other factors, but I would like to bring more attention to the FX-4300 specifically, and create a post that helps those of us (me included), who are either having issues, or just don't understand overclocking to its fullest potential.
Now to begin, my build is as follows:
PSU: XFX 850W (+3.3V@24A, +5V@30A, +12V@70A, [email protected], +5VSB@3A)
Mobo: GIGABYTE GA-990FXA-UD3
CPU: AMD FX-4300
RAM: G.SKILL Ripjaws 8GB (2 x 4GB) (F3-12800CL8D-8GBXM)
GPU: Gigabyte GTX 670 Windforce Edition
HDD: Raid 0 - 2 TB (1 TB 7200 HDD x 2)
Current clocks and voltage is as follows:
PSU: The same o.o
Mobo: CPU PLL - 2.500 V | DRAM - 1.510 V | NB Voltage - 1.125 V | HT Link - 1.225 V | NB/PCIE/PLL - 1.785 V | CPU NB VID - +0.125 V (1.3125 V) | CPU Voltage - +0.075 V (1.4500 V)
CPU: Core Speed - 4560 MHz @ x19.0 | FSB - 240 MHz | HT - 2400 MHz @ x10.0| NB - 2400 MHz @ x10.0
RAM: Frequency - 1599 MHz | 8-8-8-24-1T | Voltage - 1.51 V
GPU: Core - 1306 MHz | Mem - 3442 MHz | Voltage - 1.175 V
HDD: The same o.o
I have C1, C6, APM, Thermal Throttling and any other power saving features off.
This is my highest OC that I can achieve with semi-stability. What I mean by that is when I run Prime 95, after about 10 minutes my 2nd core fails, while all the rest keep running fine for quite a while.
My temperatures for my CPU are always below 50 degrees, my NB is the only thing that heats up a bit, and reaches a max of 55~ish. I have a large air cooler. (XIGMATEK Gaia SD1283 120mm) Going to a Corsair Hydro Series H60 within a few days.
Heres my CPU-z validation UNDER LOAD if that helps (http://valid.canardpc.com/2625743). If you need any more information, please let me know.
Now I would like to know what I can do to achieve a higher overclock, and what other people have reached. I've tried adjusting my FSB from 200 to I think the highest it would boot was around 265~ish. I've tried changing voltages non-stop EXCEPT for the CPU PLL.
And last but not least, a few questions:
What is considered a "safe" voltage? (I hear anything above 1.5v for the CPU degrades the CPU die)
What exactly does changing the CPU PLL do? (Biggest reason I haven't touched it)
Does slightly undervolting the NB/PCIE/PLL give better OC capability? (Read that somewhere as well)
CPU: AMD FX-4300
PSU: The same o.o
HDD: The same o.o
