- Dec 23, 2012
- Thread Starter
- #41
Er let me clarify.
With the FSB at 200, CPU at 4.0GHz, NB at 2.0GHz, and HT at 2.6 GHz, my system worked fine and was stable.
With the FSB at 200, CPU at 4.0GHz, NB at 2.2GHz, and HT at 2.6 GHz, my system would still not pass Prime95 for more than a few minutes, and Windows Aero DID NOT work. -This showed my Norbridge probably wasn't stable.
With the FSB at 200, CPU at 4.0GHz, NB at 2.2GHz, and HT at 2.0 GHz, my system would still not pass Prime95 for more than a few minutes, and Windows Aero DID NOT work. - This showed it wasn't dependant on my HT.
With the FSB at 200, CPU at 4.0GHz, NB at 2.2GHz, and HT at 2.6 GHz AND upped voltages for CPU-NB and Northbridge, my system would still not pass Prime95 for more than a few minutes, and Windows Aero DID NOT work. -This showed it wasn't voltage dependant.
With the FSB at 240, CPU at 4.0GHz, NB at 2.16GHz (as close to 2.2GHz as possible), and HT at 2.16 GHz with STOCK voltage, my system would still not pass Prime95, BUT Windows Aero WOULD work. -This would seem to indicate it was FSB and voltage related.
With the FSB at 240, CPU at 4.0GHz, NB at 2.16GHz (as close to 2.2GHz as possible), and HT at 2.16 GHz AND upped voltages for CPU-NB and Northbridge, my system would pass Prime95, and Windows Aero WOULD work. -This would seem to indicate it was FSB and voltage related, and is justified by being fixed.
Hope this helps =/
Also just tried upping my Vcore to 1.500 (from 1.475), CPU PLL to 2.80 (from 2.65), and raising my CPU multi from 19 to 19.5 to give me 4680 MHz (240 FSB) and the 2nd core failed almost instantly. All the others seem to be fine. Temps were still way in the green.
Hope this helps =/
