hi all,
I have run my prime for the past 6-7 hours on the setting I found stable as follow:
cpu multiplier :20.5(was 20)
fsb :213 (was 200)
cpu vcore :1.4405 ( was 1.3250)
cpu nb voltage :1.1641 ( was 1.1625)
ht multiplier (12)
nb multiplier(11)
dram ( 2133) which is now 2272 as a result of fsb increase
timing :13-13-13-37 which was 14-14-14-37
core temp:below 60
socket temp: below 60
board temp:below 60
power draw:400w ( have a measuring power tool)
I have two questions:
1. my vcore on cpu z is shown as 1.440 but when loaded with small fft it is 1.39, is in't that a big loss? my board doesn't have llc for voltage
2.at some point i had to do cmos clear and saw that the cpu voltage can be increases as high as 1.8 but shortly after that option disappeared and the max now is 1.4405, has anyone experienced this ? is this a bug?
Edit: I am using hardware monitor, core temp and speed fan.
just seen speed fan saying my temp 2 is 127 degree, googling around that is the nb, is that right ?
the system is stable so not sure if speed fan is showing false data .
the hwmonitor only has hwmonitor and that is all below 60
127 is not moving even when i stopped prime and blowed cold air into the case(fan tower)
everything else is good but speed fan is fixed on that temp so think it is false data
