Hey guys do you think it's a good idea to use Vdroop or should it just be disabled?
http://www.memoryexpress.com/Products/PID-MX20893(ME).aspx
this is the ram I have.
Hmmm, wish I knew more about that chipset. Not sure how that would compaire to the P45 boards most people are getting good clocks on.I have a Evga 790i ultra ftw
I need to! It's not so pretty with all that dust and tar is it.Not going to lie man, thats one dirty inside your rig! Clean out that dust, your computer will love you for it!!
I seem to be hitting a wall at 3.0ghz, I have the arctic cooling freezer 7. So I just purchased the scythe mugen 2 today to see if i can push it further.I've gotten it to 3.0ghz, but it won't post any higher than a 430fsb, i've tried pushing up the voltage on both the cpu and memory but it doesn't do anything. I feel kind of stuck, I don't know what else I might want to raise, ect. ? According to Cpu-z I don't get ANY vdrop, power seems pretty stable. Under load Cpuz says I'm running 1.36v (set at 1.352500 w/e on the board) The pencil mod seems to be for a P5E-vm, I'm not sure if there is a difference between that and the P5Q, though I'm not a huge person for messing with that kind of stuff (bad experience w/ soldering, 2 xboxes and 1 ps2 slim, all gone down the drain :-\ lol)
Xigmatek s1283 dude!!!!!!
my memory timings right now are at 5-6-6-17.. should i alter mine, i can not get past 2.6ghz on my q8200 ive raised vcore and still nothing. so should changing the ram timings help? and if so, what should i change them to?
Thanks
