- Jul 31, 2009
The 55C is that a temp from one of the cores or cpu overall temp?
If its a core temp its nothing to worry about under load ,if its cpu overall temp it might be a little high but it depends what the hottest core is doing.
Stock intel HS is probably ok up to around 3.0 Ghz.
If you are gonna push it more get a good air cooler bu thats 60-70$.
To get a decent water cooler setup just for the cpu even that would be better than air you will be well over $100 more like $150 and hey you could by an Q8400 for that.
Thanks kick for the advice. 55C is Core1 using realtemp. For the past few days, the system seems to be stabilize down with Core1 50, Core2 52, Core3 48, Core4 50 with Bitcomet, eMule, IE8 and movies, music running at background, room temperature 25C. I am happy with this now.
