Yes, it will fit in one of the PCIe ports. It will not fill the full length of the slot though, so that's why you may be confused.
Any reason why you want that card? Do you have a budget?
Yeah, most cards will support JBOD.
Just wanted to make sure you were making an informed decision .
I've got both the P9X79 Pro and standard P9X79 Asus boards. In the pro, I have a 3Ware 9690sa-8e (as in my sig) and in the vanilla, I have an LSI MegaRAID SATA/SAS 9260-8i, neither of which fill a full-length x16 slot, and both are working quite well.
Sure. $70 bucks or so for an extra 4 SATA III ports, and the benefit of RAID if you ever want it.
I just wouldn't expect great things in terms of speed.
Yup, using JBOD, you're essentially using the card for additional SATA ports.
lol, good stuff dude. Let us know how it works for you. Sorry I couldn't respond sooner!
Hey Peugot hows things in Norway, have you got rid of all that Snow yet? AJ.
Sounds a nice time of year buddy, yeah fishing in the rivers again! If you got time just started my new build, if you want to take a look? AJ.
1, http://www.overclockers.com/forums/showthread.php?t=728200
Sorry to jump into your thread, but its quite and just wanted to say hello!
so now i got it, and it seems to work fine, but the disc i put on it have same problems as the internal satas had.. but it connects and detects it at least, so need to put that to another disc and format it and then test speeds! it also it really small and did fit in a pcie2.0 x1 =)
