Increase the CPU Overvoltage from +50mv to +100mv. You certainly have enough core temp headroom to do that. That should help with stability.
Thanks, I'll do more tests later, when the ambient temps will hit the max (32C°, now are 26/27C°).
Anyway the twice of 383.3 is 766.6, not 686.6 like you said, or I miss something?
I don't think to be so far from the stock mhz of the ram, or 33.4mhz is a
necessary improvement for the stability?
Bad news Unfortunately I had to revert to default because (I do not know why) the
multiplier of the processor goes randomly from 12 to 6 without any reason! What could be the problem? That's very odd!
NOT odd at all if Cool N Quiet is still enabled in bios and if Win 7 power mode is not set to performance for starters.
