- Apr 29, 2005
- MA
Well after about a year and a half since any upgrade of any sort I finely decided to bight the bullet and build a new system. My wife’s laptop just died so I promised her I would give her my old rig, witch makes her happy. But if she finds out how much I spent on parts for the new rig I’m a dead man or as my title suggests a single man.
So I wanted to do something a bit custom and totally contained. You know I actually want to have the side on my computer for once. So I’m going with water-cooling and a large enough case to hold everything in it. I work in a machine shop and have some pretty good equipment available so I’m going to try to incorporate a decent amount of custom finishing touches.
Some of the mods I’m planning are complete disassembly of the case to deburr and smooth all edges and anodize, paint or powder coat all interior parts that are not already black. A couple holes in the side panels one of witch will show the coolant level in the reservoir maybe a flow gage. Gutting the bottom of the case to fit the radiator and pump. On the back panel I plan on engraving a large scorpion using a HAAS CNC vertical milling machine. And as much stuff that comes to me as the build progresses. So I would be glade to hear any opinions or ides you guys have.
Here’s a list of my parts I have, have on order and plan to order.
Case: SilverStone TJ07 Have (can’t wait to start cutting holes in a $300 case)
CFP51 hard drive transfer bracket
FP51 3.5 Transfer bracket
PSU: Corsair HX620W Have
MOBO: ASUS striker extreme Have
CPU: E6300 Have
RAM: Corsair Dominator 8500C5D Have
Video Card: EVGA 8800 GTX Plan to order
Hard drives: 2 74GB NEW Raptors Have
CPU water block: Storm Have
GPU water Block: EK full coverage Have
Pump: MCP 655 Have
Radiator: Black Ice GTX 240 Have
And I’m sure there are a couple other things I haven’t listed but will as it comes to me.
Hers a picture of what I’m starting with minus a couple parts I’m waiting for.
My RAM and CPU I let dylskee borrow to run mem test on the memory and let him play with the CPU. But for some reason he hasn’t given them back yet!!!
If you guys noticed the parts are on a conference table. I keep all the parts at work so my wife doesn’t get to curious as to how much I’m spending.
Hopefully I'll be updating with new picks on an almost Dayle basis. I've been waiting along time to build my new rig and want to get some serious progress on it.
CPU: E6300 Have
Pump: MCP 655 Have
