But what's in the box? cpu pot? gpu pot? both?
Air cooler and there's a good chance it would pretty much die on boot (although I boot at "only" 1.6v). That said...this chip's been tougher than I'd have thought. Had llc maxed and too many volts...it showed 1.993v the moment I started a bench. Quick flick of the power switch, hoped for the best, turned it on, no problem. I got lucky.That last picture though! What a beauty!
Those volts make my seating body part clench up! How fast would a CPU melt at 1.88vcore with typical aio or air cooler? I mean it's still under 2 volts, should be fairly safe, right?
Thanks Blaylock. My prior sticks were much stronger but, unfortunately, they be dead nowWow very nice Stephan. Very nice clocks, especially those sticks.
I'll try not to try anything higher than 1.6 then. I guess throttling and/or safety features don't have enough time to kick in to save her?
Hiya Metal! Yeah man....that thing's a bear of a bench. I know a lot of folks that won't even run that one due to dead chips.Good benching Stephan! Be cautious of the x265 4k, its a CPU killer.
Ummm....you might want to start around 1.3v and work your way up keeping a very close eye on temps. You don't want to get over around 70-75C under full load. 1.6 on air or aio could be deadly.Cool! I had(still have) 9800gt(not gx) and that was the last card that was single slot. Loved her!
Hi Mr.Scott! Guess I shoulda mentioned the ln2 part ;PKnock yourself out. There is no safety feature for over voltage.
Stef is on LN2. Unless you are also, chip will be dead.
You are no overclocker.
Some motherboard have a vcore limit. We tend to mod the boards, the BIOS, or both in our never ending quest for the magic smoke.
