neovalentine said:Huh? When I took that screen pic I had set it to Auto detect then went in and under clocked it to 185. That's all.
Statik said:um, are we missing that he wrote that he has pc2700 ram. that mean ddr 333... which mean it should run stock at 166 fsb. he is trying to run it at 200...
ANY ONE ELSE SEE THE PROBLEM HERE!!!!!
you are trying to run pc2700 ram at pc3200 speeds. if you up the voltage to the ram and maybe loosen the timings, you might get 200 on that ram, but i doubt it.
you are trying to run stock, but if you run the proc at stock, then you are massively oc'ing the ram. other option it to lower the ratio. no more 1:1. try 5:4. that should give you about 160 for the ram if you run at stock 200. then you even have a little oc'ing room.
EDIT: sorry, didn't see if trying at 185, but this is still a bug oc for that ram. try a ratio of 5:4. that should do it for you i am thinking. you are just (accidently, not intentionally) trying to oc the ram too much without extra voltage or looser timings.
neovalentine said:Huh? I know I have all my safety things set to Disable. Like system shutdown and what not.
