- Aug 5, 2002
The C is the revision on the chip. The C is really the 200FSB and the Hyperthreading signature for the chip.
Statik said:if it's not to much though, and you can rma the pc2700... i say just spring for the pc3200 instead.
Statik said:yeah, what you are doing now is running the fsb at about 210. that means with the ratio about 140 for your ram. it's stable here because you are now running ram rated at 333MHz (166FSB x 2 ram multiplier) and your proc rated at 200FSB at around 210 (very slight overclock, easily managed). everything should run fine here.
... as opposed to before where you were running 200 fsb for both. now for the proc, that is normal stock. but for the ram, it is about a 20% oc, a pretty high oc for ram.
do you see where i am going with this? with the 3:2 ratio, i would think that you should be able to push it up to around 250fsb and still be okay FOR THE RAM. that might start pushing your proc though.
so, do you follow me neo?
Statik said:bandit, what ratio are you running, 3:2? cause 248 fsb is VERY improbable with pc2700 ram at 1:1... that means you are running it @ DDR500 SPEEDS!!!!! 250 at 3:2 though would give you 166 though...
