- Dec 27, 2008
Here is the place to adjust the HT Link Speed in bios. Take it off "Auto" and select 1800. Because you are overclocking with the system bus, it will show up as 1980 mhz. If you continue to increase the system bus, which is now at 220 mhz. you will want to set the HT Link Speed to 1600 in bios to keep it below 2000 mhz. What you set it to in bios will change as you change the system bus speed because the two are linked. The choices for HT Link Speed in bios are based on a system bus speed of 200 mhz.
