Frito, some suggestions:
1. Thanks for attaching the pics as requested. However, when you group too many together in one capture like you did in post #8, the image gets downsized too much by the built-in forum tool (to meet the maximum file size limit) that it's very, very difficult to read the values presented in the CPU-z interface. Please capture the images separately and then upload them individually. I know it's more work for you but we can't help you if we can't read the values. You can attach up to three images at a time and if you need to add more you can by editing the post later.
2. It is evident to me from your low min CPU vcore in HWMonitor (post #13 shows a min vcore of .96) that you still have the "green" stuff enabled and that can wreak havoc with an overclock once it gets into the higher ranges. Please disable Cool N Quiet and C1E in bios. Then go into Windows Control Panel Power Options and configure it to High Performance if it is not already that way.
3. When we ask for an attached pic of HWMonitor we mean that we want one captured immediately after a stress test is run (20 minutes of the Prime95 blend test). It does us no good, generally, to know what your idle temps are. What we are after is max temps under load. Having said that, idle temps can be helpful if they seem to be unusually high as that points to a CPU cooler problem like it not being seated properly or the thermal paste not being applied properly.
4. What would really help us help you the most in trying to overclock from the bios is to have you attach some digital camera pics of the overclocking sections of the bios, i.e., the ones showing frequency and voltage adjustment. There has to be some logical reason your system crashes when you try to use the bios to overclock. By the way, you cannot have AMDOD actively loading a profile when you overclock from the bios because then you are adding an overclock to the overclock. So when you overclock from the bios, make sure AMDOD is not configured to automatically load an overclock profile when Windows boots.
