- Dec 27, 2008
2000 mhz is the stock frequency for both the HT Link and the CPUNB. It will not change when you are using the multiplier only to overclock. When you use the FSB to overclock (aka, "CPU frequency" and "HT Reference") not only will the CPU speed up but so will the ram, the HT Link and the CPUNB. Since the FSB is the master system bus, these other frequencies are tuned to it. I'm suggesting to see how far you can overclock using only the multiplier and then go back and tweak the HT Link and CPUNB separately as this is a simpler approach. Then after trying that approach you can go back and try a combo of the multiplier and the FSB to see if it is better.
