Side random question: what do you guys usually do when waiting on P95 to run?
Prey that it doesn't catch fire
also are you setting the ram voltage to 1.65v at 1600?
Mark
If that failed then you're not going to get much more from it via the CPU multi, I would do what RGone said and run the multi at the last known good setting and clock the CPU up via the fsb from there as once they hit a wall on the CPU multi it takes a big hike in vcore to make the next step and you're not going to get there as you're on 1.5v now and that's about as much as I would run 24/7 and then that's quite high for a daily vcore.
