willlangford said:thanks. but i couldnt find the timings? could someone help me as to waht they are?
thanks
~Will
pelikan said:I ordered two $59. sticks yesterday. I will post results. This memory is on the Asus compatibility chart for the A7N8X: http://www.asus.com.tw/mb/socketa/a7n8x/A7N8Xqvl.htm
My Samsung needs Cas 2.5-3-3-6 to run at 200fsb, and maxes out at 205fsb. I know my A7N8X has more headroom. So, we'll see how this TwinMoss does. Most reports I've read were great.
pelikan said:Yes, that Samsung worked out great. Now, as usual, I want more.
hitechjb1- Nice FSB. What cooling are you using on your NB? Any other mods worth noting?
XJ said:'Corsair 512MB DDR XMS3200 Platinum CAS2' - £127.55.
'TwinMOS 512MB DDR PC3200 CAS2.5' - £78.90.
Now, I can notice the price difference on there, an Akasa Copper heat spreader is like another £10 so throw that on and for £89 you got a pretty decent stick of RAM. But what i need to know is, will it o/c aswell as and keep up with the Corsair? If someone has already tested this then great, otherwise, i may just go for the Corsair and save risking the loss in performance.
~~XJ
note: will the corsair pc3500 yield a significantly greater performance than the 3200's?
hitechjb1 said:
I heard for 6ns chips, Samsung PC2700 has good yield and oc-capability. And now for 5ns chips, looks like WindBond performs real well.
I got "lucky" and my A7N8X MB can run out of the box w/ FSB to 211-217 in sycn, and 233 MHz 50-80% ASYNC at stock NB HS. I don't want to mess around w/ vmod on this particular board.
willlangford said:i dont know. but will the twinmos go over 200 fsb? because i am getting a barton and i want to run it up as much as i can.
Thanks
~Will
ezeKieL987 said:where are you guys finding this stuff for $59 at?
