My current specs are:
AMD Phenom II X6 1075T Thuban 3.0GHz
AMD 6950 2GB version
Gigabyte 870-ud3 revision 2.1
8GB (2GBx4) DDR3/1600MHz Dual Channel Memory
Asetek 510LC Liquid Cooling System 120MM Radiator & Fan
Azza Solano 1000 Full-Tower Advance Cooling Case w/ Dual 230mm Fan + Extra 3 Fans
I'm been contemplating what to upgrade in preparation for Rome 2: Total War, and just for future games in general. Since I have revision 2.1 of my motherboard, I don't believe it supports the new AM3+ CPUs. This is the main thing holding me back from getting the AMD FX-8350, as I have absolutely zero experience in replacing a motherboard. The only thing I've ever replaced is a video card and a PSU. Also, it will cost me extra to buy a new motherboard that supports AM3+, which I'm not really looking forward to.
I'm also considering the possibility of overclocking, at least as a short term solution, but I have no idea how. If you guys have any advice on which decision to make, or possibly other options I haven't considered, that would be great. Thanks for any help.
