- Jan 13, 2005
it seems to me that the patch to UT3 may have fixed some of the issues with the multiplayer side of things in UT3
now i see a few things pertaining to hell spawn arcade on there but do these fixes fix the connection issues and the strange lag never before experenced in any UT game before?
basicly does online seem more like UT's online play like before and not the same game spy **** thats used in the battle field games and other FPS games that people lose interest in very quickly because of the lack of people playing online because of the crappy online services?
http://utforums.epicgames.com/showthread.php?t=591638 said:Server Browser:
- Implemented History tab page in server browser, with ability to "lock" favorites on that page.
- Implemented a Favorites tab page in the server browser.
- Added 'Join as spectator' feature.
- Server browser uses smaller font to display more servers.
- Fixed custom mutators not appearing in server browser.
- Fixed custom gametypes not displayed in server browser's window.
- Fixed server browser's listed MaxPlayers being incorrect.
- Added filter option for dedicated servers.
- Fixed server browser showing an incorrect goal score and time limit when the .ini values were used.
- Fixed incorrect mutators appearing in server browser details if client & server are not using the same language
User Interface:
- Can now save settings/progress even if have never created a profile.
- Added ping and connect time to scoreboard.
- Removed annoying confirmation menu when starting a game.
- Removed unnecessary top settings page (can use tabs at the top of the settings to navigate).
- Added a Messages tab to the mid game menu.
- Friends messages now saved until explicitly deleted.
- Finer control over mouse sensitivity, using an edit box instead of a slider.
- Added framerate smoothing and FOV options to the advanced video menu.
- Increased max players/bots in menus to 32.
- Fixed auto switching to vote menu at end of match.
- Improved mid game menu performance (don't render world behind it).
- Added version number to main menu.
- Fixed binding gamepad/joystick keys (you must set AllowJoystickInput=1 in the [WinDrv.WindowsClient] of your UTEngine.ini to enable gamepads/joysticks).
- Fixed up the GDF project for Vista
Networking:
- Implemented STUN support (Simple Traversal of UDP Through Network Address Translators) to enable clients and servers to connect from behind a NAT.
- Fixed "open" console command when connecting to Internet servers
- Fixed team scores very rarely not updating for a client.
- Fixed bot faction option when running a listen server.
- Fixed link setup not reset correctly when going from a map with a custom link setup to one using the default.
- Fixed a case where Duel would place an incoming player on the wrong team when some players were still travelling.
- Bullseye stats are now properly recorded.
- Fixed clients not travelling to downloaded maps correctly.
- Fixed the client and server getting into a loop sending each other close messages in some situations.
- Quick match incorporates player rating into search decision.
- Fixed issue where Vista clients would not receive all servers from a server browser search.
- Applied proper fix to suppressing voice on dedicated servers.
- Fixed issues with players not getting on right team in Duel and Duel+Survival if a player leaves in certain timing windows during map transitions.
- Fixed previous level PRIs showing up on the scoreboard/leaderboard after the client travels (making it look like players have already scored lots of points when those clients are in fact still loading)
- Fixed losing your custom character mesh after changing teams during a match.
- Implemented DUEL match stat reporting for gamespy ladder.
- Fixed bugs and exploits associated with ServerViewNextPlayer()/ServerViewPrevPlayer()/ServerViewSelf() being received after the server has already moved the PlayerController out of the spectating state
- Added "BecomeActive" exec to switch from spectator to player
Server Administration:
- Dedicated servers do not require CD keys.
- Added -configsubdir= command line option to cause .ini files to be loaded/saved from the specified subdirectory of Game\Config\
- Added QueryPort configuration and command line option.
- Added an "AdminChangeOption [option] [value]" console command for server admins. This allows changing most simple .ini values (e.g. GoalScore) from the client. This command will not override URL options. The change will take effect after the next map change.
- Added an "AdminPublishMapList" console command for server admins. This overrides the server's map list for the current game type with the one on the client that used the command.
- Uses GameReplicationInfo.ServerName if set for the name of the server on the server browser.
- Added "AdminForceVoiceMute" and "AdminForceVoiceUnMute": Stops/Starts a player from sending voip to others
- Added "AdminForceTextMut" and "AdminForceTextUnMute": Stops/Starts a player from send text messages to others
- Updated AdminPlayerList to show the PlayerID of the players on the server.
- Updated Kick/Ban to allow for using either the player name or the id
- Fixed servers advertising as the wrong gametype if the gametype is changed without restarting the server
- Fixed IP addresses being reported in host byte order instead of network byte order
- Added new IdleServerTickRate property to IpDrv.TcpNetDriver. If not set, IdleServerTickRate defaults to MaxTickRate. Can be set to lower values to reduce server CPU utilization when 0 players. Reported ping will increase if set lower.
