- May 8, 2011
- Darlington, South Carolina
Here is the Odd thing. You seem to have accomplished the very thing I am talking about here: http://www.overclock.net/t/1633988/chilled-water-cooling-vs-3-0-build-log Isn't that you??? You claim to have accomplished this with 300 watts of power on 3 TEC. Am I so wrong? Why are you coming at me with a pitchfork?
Please disregard the Sock Puppet comment.
Yes that is my setup, and I am not trying to pitchfork you, it seemed odd that you were defending someone that's pretty much discounted all attempts to aid or advise or show an operational system.
But there's good reason for that as this section is actually covering traditional water cooling.
There is an Extreme Cooling Section in this forum that covers what you're interested in as far as TEC cooling, but it's not very active at all.
I suggest you hang your hat with others that are actually using this type of cooling as they have the experience to share.
You may get advice here from those that have dabbled with it in the past but not actively using it today, that said.
You'll get more advice than you probably would ever need from the Specialized Cooling : Peltiers/TEC, cooling section at Overclock.net as there are many there using just about any way you can dream up to run peltier cooling.
As far as efficiency is concerned that word doesn't belong in the same sentence with Peltier or TEC, but my present setup is the most efficient setup to date that I have built.
Most use TEC builds for stable high CPU overclocks and efficiency they could care less about.
