- Dec 1, 2007
- Near Toronto Canada
What brand and model of SSD are you thinking of buying? Make sure your SATA is set to AHCI in your BIOS before you start using it.
Hmm? One can't do that anymore?
Hey guys,
Sorry I just realised they were some more replies to my thread, I have been busy looking for good deals on ssd and gpu. As far as GPU goes I am thinking of giving a go to galax: GTX970 HoF. I already got the SSD: it's an intel 730 240GB it was on special so I thought hey why not. Now I am having a slight problem with the installing technoob, in the bios I was set per default to RAID, but I can't find or see the SSD. I tried changing the option to AHCI, but it says windows didn't start properly, it tries to restore to a previous restore point, takes a million years to do it. I restart, try to run in normal mode but then I get a blue screen -_-.
For info my case is a DarkFleet 85 and has a 2.5 hot swap bay on the top of the case.
Anyone has ny thoughts about the galax?
Cheers
cheers bro I'll give it a go, I'd be pissed if the swap bay wasn't setup properly. I order the parts for my pc but didn't build it myself, i "trusted" a shop to do it.
But since then I got a taste of installing and trying to fix things myself
Thanks overclockers for that too, the forum is a massive help
I think i see why it's confusing. Alright I have 3 HDD, one of them runs win 7 now. I just got the SSD, and I tried to installed the SSD in the hot swap bay I have on my case (on top of it), I haven't installed anything on the SSD yet. I just wanted to check if the SSD was showing up at all. And it's not. I read that I had to change an option in the bios, which I did and that when the blue screen and win won't start started.
Hope this makes it clearer
