Hi guys,
I just bought the following setup so I can do some development with multiple VMs with no problems. I'm looking to do some overclocking to get a little more out of the system, but don't have a clue what's the best/will fit in my case. I keep seeing the Noctua on all the forums for similar setups, but don't know if water/air is what I need, nor do I know which will fit. I'm looking for any and all feedback to get the make this development box last, while getting a bit more out of the processor. This has to sit under my desk, if that makes any difference, and the office air conditioning usually stays around 72 degrees F.
Chip: AMD FX-8120 X8 3100MHZ 16MB 125W AM3+
Cooling: Stock fan
Board: MSI 970A-G46 9 Series AM3+ Motherboard
Power Supply: Corsair CX600
Video: Sapphire Radeon HD 7770 GHZ Ed. 1GB DDR5 PCIe 3.0
Case: MSI Raptor ATX Mid Tower
HD: Seagate 500GB Serial ATA HD 7200/16MB/SATA-6G
Memory: Patriot PGQ332G1333ELQK G2 Division 4 Desktop Memory Kit - 32GB (4x 8GB), PC3-10666, DDR3-1333MHz, 240-pin DIMM, 1.5V, CL9, Intel XMP Ready
You guys are the pros, so any suggestions on cooling for overclocking will be appreciated.
Cooling: Stock fan
