Mine reboots at 112c
I might just have to try that. I just though air bubbles might get introduced. I guess you just crank it down hard and should squeeze them out.
+1. Exactly.I don't realy see that much is in the tim.
if I get the same amount and mount the same way every time i seem to be ok.
if i change the way i mount the block is when the issues begain.
Yep, that's the suff.
Corrodes you say? wow, why would they make a product that does that?
