- May 22, 2011
- USA
I would probably recommend the Yate Loons on the higher FPI rad to help push that air.
Did a little research on that fan and thermalbench listed it as "average at best" so I don't know if it'd be worth paying more for that over the yates
The 360 rad is 16 fpi correct? You'll want something with a little more static pressure on that so the Helix would be a good choice.Well then I may have to look into to the swiftech fans. Should I run those on the 240 or the 360 though?
Forgot to mention I also have some Swifttech Helix fans myself. Only difference I noticed between them and my Gt ap 15's is they need a bit more voltage then the Ap 15's on initial spin up. As far as sound quality they are about the same. Again this is running them on a manual fan controller.
GTXJB just to let you know where I'm coming from, I'm not uber anal about the noise from my Pc. I have not done any real world testing but I can say this. I usually run my fan controller at 50% power at that speed I cannot hear my fans at all. The only thing I hear is the dual laing pumps and that's if I'm really trying to listen for them. At 100% on the fans yes I can hear them but I don't feel there is any discernible difference in the sound quality of the GT Ap-15 fans I have over the Helix at least not to spend the money it would take to replace the Helix with the Ap 15. Truth be told I don't find much difference between the Bitfenix fans I have and the Gt Ap 15's either. Build quality on the Ap 15's is noticeably better but I haven't had any issues with any of the Bitfenix, Helix or Gt Ap 15's I have. This is also with them running 10 hours a day at 50% usually, for the better part of 2 years.That's very interesting. From you experience, its safe to say the Helix120s and the AP-15s are very close in audibles at different speeds? If this is the case, I'll just stick with them and save $200+.
