- Oct 13, 2001
Still $30, but it one or the other.did this add to your cost at all or was it still the same $30?
so can i upgrade from XP to the Pro? i didnt see anywhere where it said?
Yes, but its a clean install, not an upgrade. This is indeed not an upgrade disc. This is a full retail version as per several emails posted by members of SD.
where did you find pro? I gots a edu address that i can use. I missed out on the other deal dang it
This thread was posted before yours.
I already ordered the Home Premium version, does anybody know if/how I can change it to Pro?
Can I upgrade from a 32-bit version of Windows to a 64-bit version of Windows?
No. If you are currently running a 32-bit version of Windows, you can only perform an upgrade to another 32-bit version of Windows. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to another 64-bit version of Windows Vista.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows Vista, you'll need to back up your files and then perform a custom installation of the 64-bit version of Windows Vista. For more information, see Installing and reinstalling Windows.
I was all ready to get 64bit as recommended, but when I read their FAQ I saw this:
How difficult is it to do this and what other features besides network domains does Pro include? Is it the better choice overall?
