Kingwin Elite SATA 3.5″ Hard Drive Enclosure
A sturdy, attractive package with easy one-button data backup – Joe
SUMMARY: A sturdy, attractive package with easy one-button data backup.
Pic
The good guys at Kingwin were nice enough to send a sample of their Elite SATA 3.5″ Hard Drive Enclosure to try out. In addition to being an external enclosure, it also has a “one-touch” backup capability.
Key Features:
  • E-SATA + USB 2.0 Combo with One-Touch backup
  • Plug & Play, hot-swapping capability,
  • External power supply
  • Aluminum construction
  • Size: 205 x 130 x 35mm; Weight: 2.5 lbs (1134 g)
  • Includes USB and E-SATA cables, driver CD and instruction manual
The back shows the usual ports plus one button for backing up files:
Pic
Remove two screws from the back and the tray easily slides out:
Pic
When you open the unit, there may be a dangling wire with a two pin connector attached to the external case – this is for the HD light and connects to the two pins indicated by the red arrow:
Pic
Parts that ship with the Elite Enclosure include a software disk for drivers and software to enable the one-touch backup function:
Parts
Overall this appears to be well made and sturdy – the aluminum case is about 1/16″ thick, so it’s not flimsy and can take some hard knocks. The drive tray is also aluminum, so the only plastic parts are the end caps and black trim pieces.
Performance Test
I tested the USB port using a Seagate 160GB, 7200 rpm drive – results are typical of external hard drive enclosures:
Pic
File Backup Function
Included with Kingwin’s Elite is software to enable the “One-Touch” file backup function. This is a “lite” version of Fnet’s PCClone Ex – this software enables file backups, not total system backups.
After installation, a PCClone icon is installed on the desktop and system tray – click on it, or hit the “one-touch” button on the enclosure, and this screen comes up:
Open
Click on the “Quick Launch” icon and this comes up:
QL
Hit the “Start” button and it proceeds to backup files:
Progress
Obviously how long it takes depends on how much you have – my wife’s laptop took about 20 minutes for 7.5 GB worth of files. It also generates a text file that lists some items not backed up, but not all. Clicking on the second menu icon brings up this:
Drag Drop
The third menu icon brings up a somewhat confusing screen:
Drag Drop
You figure out that the left side is your PC and the right side is the external drive. Finally there is a “Help” function:
Help
Adequate enough to figure out what’s going on – the last two screens are “drag and drop”, so you can select whichever file you either want to backup or restore. Overall a handy software package.
CONCLUSIONS
Kingwin’s Elite SATA 3.5″ Hard Drive Enclosure is sturdy, attractive package with easy one-button data backup, which is a nice addition to the usual external drive package.
Thanks again to Kingwin for sending this our way.
  1. Kingwin Big Drive – Dual SATA RAID Enclosure
  2. MAPower KC-31 3½” SATA Hard Drive Enclosure
  3. Kingwin Portable 5.25″ Aluminum Hard Drive Enclosure
  4. Kingwin Mini Shuttle 3.5″ Hard Drive Enclosure
  5. Kingwin Aluminum 3.5″ Hard Drive Enclosure
Tags:
