Not all cases have room for a full tower heatsink. So, Noctua provides a blow-down variety with six heat pipes and a 140 mm fan. That was the NH-C14, and it is quite a cooler. So, what’s new? The NH-C14S (note the change in the model number), with the finstack moved over to make room for cards in the top PCIE slot. How well does this heatsink cool? Let’s find out.
Noctua is well known for its superb heatsinks and fans. You might say we are blown away by their products. This time around, they have modified their well-proven NH-C14. This is a blown-down heatsink. Why use a blow-down heatsink? You may have noted that some these heatsinks blow air directly on your RAM and or VRMs, cooling it. That’s one reason. But probably the most common reason is to use a narrower case.
The C14 uses a 140 mm fan and six heatpipes to achieve its cooling prowess. But there is one thing wrong with the 140 mm fan and accompanying finstack – they are wide enough that they sometimes impinge on the first PCIE slot. This is often not too much of a problem when your x16 card fits in the second slot of your motherboard, but there are a number of motherboards where the top slot is filled with a graphics card. This is true of some enthusiast boards, most HEDT boards and all micro ATX boards. But the physics of heatflow mean that a 140 mm finstack radiates more heat than a 120 mm finstack.
Noctua did the sensible thing and moved the finstack sideways to produce an asymmetric heatsink that preserves the 140 mm finstack while making room for cards in the top PCIE slot. So sure are they of this heatsink’s abilities that this version (the NH-C14S) will replace the older version (the NH-C14).
Features of the NH-C14S
From the product page. Some descriptive paragraphs were not reproduced.
Based on the award-winning NH-C14
C-Type top-flow design – Run with the NF-A14 fan installed underneath the fin stack, the NH-C14S stands only 115mm tall, which is much lower than tower coolers with 140mm or 120mm fans and allows it to fit many desktop style or HTPC cases.
High Clearance Mode – Run with the NF-A14 fan installed on top, the NH-C14S provides extended clearance underneath the fin stack. This way, it is fully compatible with chipset coolers and RAM modules with heat-spreaders of up to 70mm height.
Offset design for PCIe clearance – Compared to the original NH-C14, the layout of the NH-C14S has been offset in two axis. Thanks to this measure, the heatsink will clear the top PCIe slot on most µATX and ATX motherboards when the bendings of the heatpipes face the PCIe slots or the I/O panel.*
NF-A14 140mm premium fan
PWM support and Low-Noise Adaptor – The NF-A14 premium fan supplied with the NH-C14S supports PWM for convenient automatic speed control through the motherboard. In addition, the maximum fan speed can be reduced from 1500 to 1200rpm using the supplied Low-Noise Adaptor for even quieter operation.
SecuFirm2™ mounting system – Noctua’s SecuFirm2™ mounting systems have become synonymous with quality, safety and ease of use. Supporting Intel LGA115x (LGA1150, LGA1151, LGA1155, LGA1156), LGA2011 (LGA2011-0 & LGA2011-3) and AMD (AM3(+), AM2(+), FM1, FM2(+))
Compatibility with past and future sockets – Complying with the open SecuFirm™ standard, the NH-C14S can be made compatible with the older LGA1366 and LGA775 sockets using the optional NM-I3 mounting kit, which is provided by Noctua free of charge. If technically possible, Noctua will also provide upgrade kits for future sockets.
NT-H1 thermal compound
6 years warranty – Noctua products are renowned for their impeccable quality and outstanding longevity. Like all Noctua fans, the supplied NF-A14 features an MTBF rating of more than 150.000 hours and the entire NH-C14S package comes with a full 6 years manufacturer’s warranty. [/quote]
Hold onto your receipts. From my own interactions with customer support and the interactions of others, I can tell you that Noctua provides world class support to their customers.
Specifications for the NH-C14S
Compatibility | Intel LGA2011 & LGA2011-v3, LGA1156, LGA1155, LGA1150 & AMD AM2, AM2+, AM3, AM3+, FM1, FM2, FM2+ |
Height (without fan) | 115 mm |
Width (without fan) | 140 mm |
Depth (without fan) | 163 mm |
Height (with fan) | 115 / 142 mm |
Width (with fan) | 140 mm |
Depth (with fan) | 163 mm |
Weight (without fan) | 820 g |
Weight (with fan) | 1015 g |
Material | Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating |
Max. TDP | see TDP guide |
Fan compatibility | 140x140x25mm (with square frame) |
Scope of Delivery | 1x NF-A14 PWM premium fan Low-Noise Adaptor (L.N.A.) Fan clips for second fan NT-H1 high-grade thermal compound SecuFirm2™ Mounting Kit Noctua Metal Case-Badge |
Warranty | 6 Years |
Fan specifications | |
Model | 1x Noctua NF-A14 PWM |
Bearing | SSO2 |
Max. Rotational Speed (+/- 10%) | 1500 RPM |
Max. Rotational Speed with L.N.A. (+/- 10%) | 1200 RPM |
Min. Rotational Speed (PWM, +/-20%) | 300 RPM |
Max. Airflow | 140,2 m³/h (82.5 cfm) |
Max. Airflow with L.N.A. | 115,5 m³/h (68 cfm) |
Max. Acoustical Noise | 24,6 dB(A) |
Max. Acoustical Noise with L.N.A. | 19,2 dB(A) |
Input Power | 1,56 W |
Voltage Range | 12 V |
MTBF | > 150.000 h |
When I did on my own testing of this fan, I found the specs to be accurate. BTW – the LNA for this fan is the NA-RC7.
Packing
As is usual for Noctua, the heatsink’s box arrived from Austria inside a shipping carton. It has nice bits of marketing all around.
Noctua packs the top of the box with accessory boxes, which help protect the heatsink.
They encase the heatsink with cardboard. Link to prior review where we have seen that the packing in fact protects the contents. The fan comes clipped to the heatsink, so nothing comes loose during international shipping.
The NH-C14S Unpacked
Looking from the end, the heatpipes are symmetrically placed to both sides of the center support rod. From the looks of the picture, it appears that Noctua have moved the finstack over by about a centimeter. I’m sure you have noted the extra set of clips for another 140 mm fan.
Seen from the open end, you can see that the center piece is a solid rod that passes through above the contact body of the heatsink. The two captive pre-sprung screws at the bottom will fasten the heatsink to its mount.
The new backplate has bolts that are press-fitted into place. That makes it suitable for only the LGA115x socket. If you have LGA1366 and LGA775, you can write to Noctua for a free backplate and bolts. From the other side, the bolts go through the motherboard, through spacers, and through the two brackets. Four thumbscrews hold the brackets tight. The brackets hold a pair of bolt-ends. Those are what the captive tension screws meet when the heatsink comes down.
The contact surface of the heatsink is not a perfect mirror. In fact, it is a slightly convex machined surface. Since Noctua thinks through everything they do, then test everything they design, the fact that this is not a mirror means that it conducts heat better this way.
This view of the NH-C14S shows the two holes in the finstack that allow the screwdriver through. Your screwdriver shaft will go through these holes when you screw down your heatsink.
This picture shows that the support rod is actually a sandwich of metal. It also shows that the rod is braced. Finally, it shows that the heatsink is 11.5 cm from the contact surface to the other side of the finstack, just as Noctua promises.
The next picture shows a closeup of the heatsink mounted to a motherboard. There is a card in the top slot, and at least a cm between the finstack and the card. Plenty of room. Mission accomplished.
One other issue: the NH-C14S was designed to give lots of clearance to tall RAM. I don’t know about you, but these days I buy low profile RAM – as low as I can find. With vDIMM dropping, there seems to be no reason for tall RAM heatsinks, unless you are overclocking your RAM. In any case, here is the NH-C14S hovering over the motherboard. You can see it has lots of room for normal RAM with the fan in the lower position. If your Ram is taller, put the fan on top.
Test Setup
CPU | Intel i7 4790k @4.4GHz, Vcore set to 1.19v, Vcore actual = 1.212v |
TIM | Noctua NT-H1, 6mm blob centered on IHS of CPU |
Motherboard | Gigabyte GA-Z97X-Gaming 7 |
RAM | Crucial Ballistix Sport Very Low Profile 4GBx2 DDR3-1600 1.35v |
GPU | Intel HD Graphics 4600, integrated into the i7 4790k |
PSU | Seasonic SS-460FL 460W Fanless |
OS | Windows 8.1, 64-bit |
Stress Software | OCCT 4.4.1; Linpack OCCT 4.4.1; Linpack with AVX LinX 0.6.5; Linpack with AVX2 |
Logging Software | Real Temp 3.70 |
Test Equipment | |
Digital TEMPer USB Thermometer, with logging software | |
Tenma 72-942 Sound Pressure Level Meter |
The comparator heatsink was the Noctua NH-D15. Each Heatsink was mounted with a 6 mm blob of NT-H1 TIM. Each time a heatsink was mounted, the TIM was allowed a day to fully spread before the temperature tests were run.
Each test run was 60 minutes in duration. The last 50 minutes of each run was measured, and the temperature logs were analyzed in Open Office spreadsheets. An Intel chip reports its temps in one degree increments, so for best accuracy these reports should be averaged in aggregate. Here the core temps were measured once a second, resulting in 3000-line spreadsheets. The digital thermometer measuring air temp reported its measurements in increments of 0.1 °C. The ambient temperature was measured every five seconds, resulting in 600-line spreadsheets. The mean ambient temp was subtracted from the mean core temps, resulting in a net temp for each run. The net temps were then averaged.
The heatsink was tested with one or two 140 mm NF-A14 PWM square fans, with nominal speed of 1500 rpm, 1200 rpm with the stock NA-RC7 LNA’s. Since Noctua provided not only the heatsink and the extra fan, but an extra NF-F12 PWM as well, I tried adapting that to the C14S. Of course, it would not attach with the stock clips for a 140 mm fan, but even with the clips for 120mm fans that came with the NH-D15S, the fans would not fit. Thus, you cannot use a 120 mm fan with the NH-C14S.
Back to cooling. Noctua said this: “One thing to note is that the C14S performs very close to D15/D15S at normal heatloads, but when you really crank up the heat, it will start to lose ground” (personal communication). So, of course we will look into this heatsink with three levels of heat. We have already established that Linpack stresses heatsinks more than other software. Here we are using Linpack plain (hot), with AVX (hotter) and with AVX2 (hottest). We will see whether the C14S can keep up with the big boys.
Testing the NH-C14S
A dirty little secret among heatsink testers is that your results may vary by a degree or two, depending on how much or how little TIM you put on. You also get a half a degree C difference from one run to another. Finally, manufacturing variation can make one heatsink of the same model perform better than another. But after you have minimized the variables as much as possible, you are left with this: some heatsinks are just better at cooling than others. And some heatsinks perform just as well as others. Here we have exhibit A: the NH-C14S.
You may scoff at a temperature over ambient that is merely in the mid-60’s. But add that to an ambient in the mid-20’s and you run a core temp around 90. I was getting spikes into the 90’s. This is a test system that must be scaled back to test more normal heatsinks, so these heatsinks are cooling one hot testbed.
What is surprising is how well that NH-C14S did. It kept up with the D15. Quite an accomplishment. And if you’re willing to give up maybe a couple of degrees, a pair of NF-A14’s on RC7 low noise adapters will give a very quiet cooler that performs very well.
Perhaps the biggest surprise here is that it didn’t make much difference to the temps how the fans were arranged. It made more difference to how much noise it made.
Conclusions
This heatsink kept up with the big boys. If you want a blow-down heatsink to cool your CPU and your RAM, the NH-C14S does a remarkable job. Additionally, there is room for most RAM, even with the fan in a pull position.
The contents were laid out in a straightforward manner, and the instructions were easy to understand. As usual, Noctua’s mounting system, the SecuFirm2™ Mounting Kit, was easy to use.
One item I did not cover in this review is the orientation of the installed heatsink. As I discussed in a review on the NH-L12, whether you orient the heatpipes horizontally or vertically makes a difference. So, it would behoove you to test the cooling power of your heatsink mounted with the heatpipes horizontally or mounted with the heatpipes vertically to see which is better.
You don’t have to buy an additional fan to get the most out of the NH-C14S. However, buying a second NF-A14 PWM and running them both with Low Noise Adapters can reduce the noise they make to almost nothing while keeping up the cooling. NH-C14S Pros
- 140 mm class heatsink
- Finstack has been moved over to make room for cards in the first PCIE slot
- Includes the inestimable NF-A14 PWM, with a Low Noise Adapter
- Includes clips for a second fan
- Almost inaudible with two fans on LNA’s
- Includes standard Noctua mount – very easy to use
- Cools as well as 140 mm tandem tower heatsinks
- Qualifies for Noctua’s world class customer service
NH-C14S cons
- none
Availability
High quality costs – this is not a cheap heatsink. Noctua says, “The NH-C14S is currently shipping and will be available shortly. . . . The manufacturer’s suggested retail prices are as follows: NH-C14S: EUR 74.90 / USD 74.90.” At the time of this writing, regular listings for this product were not available from Newegg or Amazon.
Click the stamp for an explanation of what this means.
-Ed Hume (ehume)
Loading new replies...
Low Profile Senior
Low Profile Senior
Low Profile Senior
