An erector set for case modders – Joe
SUMMARY: An erector set for case modders.
The good guys at PC Add-A-Fan were nice enough to send a sample of this versatile product to try out. The ancient ones among us remember the Erector Set, a toy which consisted of numerous metal parts to build just about anything you could imagine. The Add-A-Fan parts list is quite an assortment:
Included with these parts is a Manual which shows how these parts go together. Below is the complete package:
There are enough nuts and bolts to cover different mounting schemes:
The brackets that come with the set are the core of this system:
Also included are two fan shrouds which can be used to direct fan airflow:
Unless you’re screwdriver challenged, basically it’s up to you to figure out what you want to do and use the parts needed – a quick example:
There are parts to isolate the fan from the brackets to reduce noise:
Typical installations show the Add-A-Fan’s versatility:
With an MSRP of $18.95, Add-A-Fan is a very handy collection of assorted parts enough for 1-3 cases, depending upon how many fans are added to each case. No doubt you can buy some of these parts individually, but Add-A-Fan pulls together what you need in a handy package.
Thanks again to PC Add-A-Fan for sending this our way.
Related posts:
- 3RSystem IceAge 120
- Want a Little Pizazz? Add an LED Power and Reset Button
- Tuniq Tower 120
- Thermalright Ultra-120
- Swiftech MCB-120 Radbox
Tags: Systems & Components
