Kit test – Joe
SUMMARY: Entry level kits with moderate performance.
The good guys at 3R System Co. were nice enough to send samples of the Poseidon WCL-02 watercooling kit. There are two versions of this kit – the difference between them is the radiator:
The WCL-90 features a 92mm fan and the WCL-120 a 120mm fan. The 92 mm fan is rated at 78 cfm, 4000 rpm and the 120 at 116 cfm, 3000 rpm. Noise at these speeds was moderate.
Key Features:
- 12 volt waterpump
- GPU and northbridge waterblocks
- Pump Head: 650 mm (about 2.1 feet)
- Pump Flow Rate: 1.2 lpm (about 19 gal/hr)
- Aluminum Radiator
- Silicone tubing
Tubing is attached using plastic adapters which securely fasten the tubes using screw fittings.
The waterblock’s base is not well finished:
I could feel polishing ridges very distinctly with my fingernail.
Mounts (Intel CPU – Prescott, P4, P3, Xeon; AMD CPU – Barton, Duron, Athlon) that ship with the kit are quite good:
They distribute pressure over the CPU core, where it should be. I would not use a screwdriver to tighten – finger pressure is adequate to the task.
The radiator features a plenum on both sides
and tubes between.
The parts that ship with the kit
include GPU and northbridge waterblocks, assorted fittings, fluid and a rheostat for fan control. The waterblocks for the GPU and northbridge have aluminum bases compared to copper for the CPU waterblock:
The WCLs were tested using the CPU Die Simulator. The tests were run using the same components each time – the only difference was changing radiators; the waterblock was not dismounted from the die simulator during testing.
Kit | Die Temp | Ambient Temp | Delta | C/W |
WCL-90, 3376 rpm | 53.7 | 27.3 | 26.4 | 0.37 |
WCL-120, 2633 rpm | 55.0 | 27.5 | 27.5 | 0.38 |
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU
consumes, the HSF will limit the CPU’s temperature rise to (C/W x CPUw)
plus the temperature at the HSF’s fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
What I found interesting is the relatively small difference between the 90 and 120 mm fan results – I would have expected the 120 to be marginally better. I measured the radiators and found that, to my surprise, the face areas are the same – the 90 measures 3 ½” x 4¼” and the 120 4¼” x 3 ½” – both equal at 14.9 square inches (visually the 120 looks bigger). These results were confirmed in multiple tests¹ over three days – no fluke.
Die Simulator results place the Poseidon WCL-02s in the lower rank of watercooling kits tested to date (Heatsink Ranking).
The WCL-02 kits tested about where I thought they would – OK for an entry level kit and OK for non-aggressive cooling. I would recommend the 120 over the 90 as fan noise is somewhat lower.
Thanks again to 3R System Co. for sending these our way to check out.
Be the first to comment
