ADATA Technology, a leader in high-end memory modules, has announced the release of the new ADATA 2.5-inch SATA III ISSS333 PLP 3D TLC solid-state drives (SSD) featuring Power Loss Protection (PLP). This industrial level SSD with added PLP is aimed at applications and environments that are more likely to suffer from sudden power outages. They are available in capacities of 64GB to 2TB. Read below for the official release from ADATA.
ADATA Technology, a leading manufacturer of high-performance DRAM modules and NAND Flash products, is pleased to announce the launch of its new 2.5-inch SATA III ISSS333 PLP 3D TLC solid state drives (SSD) featuring Power Loss Protection (PLP). The industrial-grade SSDs are purpose made for applications that require durability, reliability, and high capacities, including industrial computing, embedded applications, surveillance systems, medical equipment, gaming machines, defense applications, and general automation. ISSS333 PLP SSDs implement 3D NAND Flash and the SATA III 6Gb/s interface for superb transfer rates of up to 560/520MB per second. For cost savings, these SSDs sport lower power consumption of 2.3 watts.
Reduce the Possibility of Data Loss
Equipped with Power Loss Protection, ISSS333 3D TLC PLP SSDs guard against data loss when a sudden power failure occurs. This capabilities comes in handy for applications that are more prone to power outages, namely those operating in outdoor environments, such as base stations, surveillance systems, and transportation facilities to name a few. What’s more, ISSS333 3D TLC PLP SSDs also feature wide-temperature resistance (-40°C to 85°C) to ensure optimal operation even in the harshest environments and polymer capacitors with short circuit protection. ISSS333 3D TLC PLP SSDs also support LDPC (Low-Density Parity-Check) error correcting code technology to detect and fix a wider range of data errors for more accurate data transfers and a longer SSD lifespan.Enhance Durability and Security
ADATA ISSS333 3D TLC PLP SSDs are rated for 3000 P/E cycles, which means their endurance, reliability, and stability are up to par with 2D MLC SSDs. What’s more, for added reliability and improved cost efficiency, the SSDs implement the company’s proprietary A+SLC technology. It utilizes custom NAND Flash firmware with an A+ sorting algorithm to emulate SLC performance. A+SLC is highly reliable, provides excellent data integrity, and delivers a superb cost/performance balance. ISSS333 3D TLC PLP SSDs also undergo ADATA’s SSD validation process, covering functionality testing and reliability validation.
Larger Capacities for the 5G Era
With the growing prevalence of big data analytics, artificial intelligence, the Internet of Things, and the larger amounts of data and higher levels of connectivity associated with 5G deployment, higher capacity SSDs are becoming the norm. To meet these demands, ISSS333 3D TLC PLP SSDs sport capacities from 64GB to 2TB.
Wealth of Added Features
For added stability and reliability both SSDs support a number of technologies including Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.), which can indicate a possible imminent drive failure, and NCQ and Windows TRIM Command to boost performance. For convenient management of the SSDs, customers can take advantage of ADATA’s SSD Toolbox, which facilitates the monitoring and managing of the drives, with drive status, wear level, and lifespan information.
Exact availability of ADATA ISSS333 PLP SSDs may vary by region. To find out about availability and prices in specific markets, please contact your nearest ADATA representative via industrial.adata.com.About ADATA – Innovating the Future
ADATA Technology is the world’s second largest vendor of DRAM memory modules, ranks among the top 20 international brands from Taiwan, and holds over 500 memory-related patents. ADATA’s main product lines include memory modules, USB flash drives, memory cards, solid state drives, and portable hard drives. With a commitment towards delivering innovation, quality, and performance, ADATA products have garnered international acclaim and awards including iF Design, Red Dot Design, CES Innovation, Good Design, COMPUTEX Best Choice, and Taiwan Excellence. The hummingbird is ADATA’s brand mascot, and it represents the company’s agility to innovate and improve people’s lives through technology. For more information, please visit industrial.adata.com
Loading new replies...
