Yesterday, AMD released its Radeon Adrenalin 21.91.1 driver update. This update adds a new auto overclocking feature for Ryzen 5000 series CPUs as well as 6000 series GPUs. Support for Windows 11 is also included as well as support for Deathloop, Call of Duty: Vanguard Open Beta, and AMD’s S.A.M. for 5000 Series GPUs. Below is a list of AMD’s highlights, fixed bugs, known bugs, and compatibilities.
Today’s Radeon™ Software Adrenalin release brings a new auto overclocking feature for AMD Ryzen™ 5000 series processors and AMD Radeon™ 6000 series graphics, and Microsoft® Windows® 11 support.
Deathloop
CALL OF DUTY: VANGUARD
AMD Smart Access Memory
Support For
Deathloop™
Call of Duty® Vanguard Open Beta
AMD Smart Access Memory on Radeon™ RX 5000 Series Graphics
Auto Overclocking for AMD Powered PCs
Gamers who have a PC powered by the latest AMD Ryzen™ 5000 series processor and AMD Radeon™ 6000 series graphics card can now take advantage of a new, simple to use, auto overclocking feature found in AMD Radeon Software. Beginning with our latest version of the Radeon Software Adrenalin ver. 21.9.1, gamers can get a boost in performance from just a simple click of a button.
To access this easy-to-use feature, open up Radeon™ Software using the hotkey ‘ALT’ + ‘R’, navigate to the ‘Performance’ tab found at the top of the window, and select ‘Tuning’ in the sub-tab directly below it.
Radeon Software Support for Microsoft® Windows® 11
Windows 11 is just around the corner, and we know many users are participating in the Microsoft® Windows® Insider Program and have access to an early build of Windows. If you’re one of those people, you can now take advantage of all the features found in Radeon Software. Download the new Windows 11 driver from AMD.com to get access to the latest performance optimizations as well as features like Radeon™ Boost, Radeon™ Anti-Lag, and Radeon™ Image Sharpening that can improve performance, reduce latency and enhance visuals. Take advantage of built-in capture and streaming tools, as well as AMD Link, a free app that can let you play your PC games from almost any connected device.
Added Vulkan® Support
VK_KHR_zero_initialize_workgroup_memory
This extension allows implementations to use the null constant initializer on shader workgroup memory variables. This in turn allows applications that run untrusted content to defeat memory-scraping attacks.
VK_KHR_shader_integer_dot_product
This extension adds support for the integer dot product SPIR-V instructions defined in SPV_KHR_integer_dot_product. The SPV_KHR_integer_dot_product extension allows dot product operations on integer vectors with optional accumulation. In addition to allowing dot product operations for all input vector types, it also allows integer dot product for 4-component vectors of 8-bit integers that are packed into 32-bit integers.
VK_EXT_shader_atomic_float2
This extension provides shaders with the capability to perform 16-bit floating-point atomic operations on buffer and workgroup memory. It additionally allows floating-point atomic minimum and maximum operations on the buffer, workgroup, and image memory.
VK_EXT_load_store_op_none
This extension allows an application to specify the contents within the render area that will not be modified or can be expected to be undefined after rendering.
Fixed Issues
Visual artifacts in PAYDAY™ 2 may be observed during gameplay on some AMD Graphics products such as Radeon™ RX 6800 XT.
Connecting two displays with large differences in resolution/refresh rates may cause flickering on Radeon RX Vega series graphics products.
On Radeon™ RX 5500 XT Graphics, higher than expected memory clock speed and power consumption may be experienced when idle and the display’s resolution and refresh rate are set to specific values such as 1080p @ 60Hz.
While playing Assassin’s Creed® Odyssey, driver timeouts or black screens may be experienced on some AMD Graphics products such as Radeon™ RX 480 Graphics when the user quickly navigates through the game menus or swiftly looks around an environment with their character
Known Issues
Open Broadcaster Software™ may continue to run in the background after a user ends a recording session and closes the application.
Driver timeouts may be experienced while playing a game & streaming a video simultaneously on some AMD Graphics products such as Radeon™ RX 500 Series Graphics.
AMD Radeon™ Software may crash or become unresponsive while playing some DirectX® 11 games such as PlayerUnknown’s Battlegrounds™ with multiple displays connected in extended mode.
Playing Horizon Zero Dawn™ for an extended period may lead to a driver timeout or game crash on some AMD Graphics products such as Radeon™ RX 6700 XT.
Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Radeon performance metrics and logging features may intermittently report extremely high and incorrect memory clock values.
Package Contents
The Radeon Software Adrenalin 21.9.1 installation package contains the following:
Radeon Software Adrenalin 21.9.1 Driver Version 21.30.17.01 for Windows® 10 (Windows Driver Store Version 30.0.13017.1004).
Product Compatibility
Radeon Product Compatibility
Radeon Software Adrenalin 21.9.1 is compatible with the following AMD Radeon products.
Radeon™ RX 6900/6800/6700/6600 Series Graphics
Radeon™ RX 5700/5600/5500/5300 Series Graphics
Radeon™ VII
Radeon™ RX Vega Series Graphics
AMD Radeon™ Pro Duo
Radeon™ RX 500 / Radeon 500X Series Graphics
Radeon™ RX 400 Series Graphics
Mobility Radeon™ Product Compatibility
Radeon Software Adrenalin 21.9.1 is a notebook reference graphics driver with limited support for system vendor-specific features.
AMD Radeon™ RX 6800M Series Graphics
AMD Radeon™ RX 6700M Series Graphics
AMD Radeon™ RX 6600M Series Graphics
AMD Radeon™ RX 5700M/5600M/5500M/5300M Series Graphics
AMD Radeon™ 600 Series Graphics
AMD Processors with Radeon Graphics Product Compatibility
DESKTOP
AMD Ryzen™ Processors with Radeon™ Vega Graphics
AMD Ryzen™ PRO Processors with Radeon™ Vega Graphics
AMD Athlon™ Processors with Radeon™ Vega Graphics
AMD Athlon™ PRO Processors with Radeon™ Vega Graphics
MOBILE
AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics
AMD Ryzen™ PRO Mobile Processors with Radeon™ Vega Graphics
AMD Athlon™ Mobile Processors with Radeon™ Vega Graphics
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
In what seems to be sort of a ‘hey, we’re still here!’ moment, AMD is celebrating the six month anniversary of its HD 7970 GPU with a refresh. They’re raising the GPU and memory clockspeeds on the reference card and releasing the AMD HD 7970 GHz Edition. They are also touting the new capabilities of some game partnerships as well as the improved coding of their Catalyst drivers for the entire 7xxx product stack.
AMD was gracious enough to invite Overclockers.com to their Club AMD event running along side, almost literally, the annual E3 video game conference. Coming into this, I wasn’t sure what to expect. Something GPU related no doubt, but it turns out it was much more than that. There are some details I am unable to share at this time due to embargos, but AMD and its partners really brought a lot of cool things out to show the attendees. Let’s take a look at a couple of them.
AMD APUs continue to evolve with better graphics and compute performance with each new release. The Kaveri APUs are no different in this regard and attempt to redefine the landscape for what can be done on a single chip solution. Several new technologies have been introduced since the release of Trinity and Richland APUs, which we’ll explore today. AMD sent along the A10-7850K APU for us to have a look at, which is the flagship model for the Kaveri line. So, let’s dive into this latest APU offering from AMD and see what they have in store for us.
Well, it seems like this is the first Radeon driver that no longer supports my older Radeon 7770. It worked with new drivers up until now, because it was their first card after they transitioned from VLIW to GCN, but I guess nothing lasts forever... My 6870 on the other hand, only one generation older, got it's last driver in 2015 so I guess I can't complain too much.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
1 reply
Loading new replies...
