Table of Contents
Today, Biostar has announced two new motherboards for the upcoming Rocket Lake-S Intel CPUs. The H510MH/E 2.0 and H510MX/E 2.0 motherboards are designed for business and lighter use applications. With so many flagship and gaming boards releasing, it’s good to see Biostar has not forgotten the business and casual sector. While these boards won’t feature extremely high VRM capabilities, they will support newer technologies like PCIe 4.0 and Wi-Fi 6.0. Both boards are micro-ATX for smaller builds and have a pair of DIMM slots capable of up to 64 GB of memory at 2933 MHz. Pricing and release dates have not been announced yet so stay tuned for further updates. Here are Biostar’s official release notes along with complete specs.
BIOSTAR ANNOUNCES THE INTEL H510 SERIES MOTHERBOARDS
Best motherboards for business use
February 2nd, 2021, Taipei, Taiwan – BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, announces the launch of their new H510 series motherboards designed to run the latest Intel 11th gen Rocket Lake-S processors.
Introduced to the market in two Micro-ATX models, the H510MH/E 2.0 and the H510MX/E 2.0 motherboards are designed to be the best choice for business and casual use. Based on Intel’s H510 single chip architecture, these motherboards are ready to unleash the true potential of the latest Intel 11th gen processors.
Equipped with all the essential features, the new H510 series comes from an immensely popular lineage of motherboards from BIOSTAR used all over the world in many offices that combine cutting edge technology with proven durability for smart business solutions.
Designed to optimize any professional workflow, the H510 series motherboards bring the latest technology for users like PCIe 4.0 and WiFi 6 optimized to perfection with the protection and stability of BIOSTAR’s proprietary Super Hyper PWM technology. Both motherboards support dual-channel DDR4 memory, optimized to run up to 64 GB and a maximum clock speed 2933MHz.
Additional features like Intel GbE LAN and support for USB 3.2 Gen1 makes the H510 series highly efficient and user friendly.
When it comes to rear I/O both motherboards are well thought out, with all the essentials packed in an almost identical layout. H510 series motherboards carry a single PS/2 Keyboard and 1 x PS/2 Mouse port specially integrated for users looking to connect an older mouse or keyboard to the system.
Furthermore, both motherboards come equipped with a single HDMI port and a VGA port. Meanwhile, the H510MX/E 2.0 contains an additional DVI-D port, providing multiple options for display connectivity.
The H510 series motherboards also have 2 x USB 3.2 (Gen1) ports, 4 x USB 2.0 ports for speedy file transfers. ALC897 chipset powers the 3 x Audio output ports provided in both motherboards, capable of outputting 7.1 channels, high definition audio for an immersive user experience.
In Conclusion, if you are a user looking for the best motherboard for business use, the H510MH/E 2.0 and the H510MX/E 2.0 motherboards from BIOSTAR are the best choice in the market. Either a system integration builds to keep your business up to date or for casual content consumption like watching TV shows and movies online such as YouTube or Netflix, the new H510 series motherboards from BIOSTAR is your smart choice.
Spec table:
Model
H510MH/E 2.0
H510MX/E 2.0
Chipset
Intel H510
Intel H510
CPU SUPPORT
Support for 10th/ 11th Generation Intel Core i9/ i7/ i5/ i3 processors and Intel Pentium processors/ Intel Celeron processors in the LGA1200 package
*Please refer to www.biostar.com.tw for CPU support list.Support for 10th/ 11th Generation Intel Core i9/ i7/ i5/ i3 processors and Intel Pentium processors/ Intel Celeron processors in the LGA1200 package
*Please refer to www.biostar.com.tw for CPU support list.MEMORY
Supports Dual Channel DDR4 2933/ 2666/ 2400/ 2133/ 1866
2 x DDR4 DIMM Memory Slots, Max. Supports up to 64 GB Memory
Each DIMM supports non-ECC 4/8/16/32GB DDR4 module
*Please refer to www.biostar.com.tw for Memory support list.Supports Dual Channel DDR4 2933/ 2666/ 2400/ 2133/ 1866
*Please refer to www.biostar.com.tw for Memory support list.INTEGRATED VIDEO
By CPU model
Supports DX12
Supports HDCPBy CPU model
Supports DX12
Supports HDCPSTORAGE
— Total supports 1 x M.2 socket and 4 x SATA III (6Gb/s) ports
4 x SATA III Connectors (6Gb/s)
1 x M.2 (M Key) Socket:
Supports M.2 Type 2242/ 2260/ 2280 SSD module
Supports PCIe 3.0 x4 (32Gb/s) – NVMe/ AHCI SSD & SATA III (6Gb/s) SSD
*When using the SATA SSD module on the M.2 slot (M2_PCIEG3_32G_SATA_1), the SATA_1 connector will be disabled.— Total supports 1 x M.2 socket and 4 x SATA III (6Gb/s) ports
*When using the SATA SSD module on the M.2 slot (M2_PCIEG3_32G_SATA_1), the SATA_1 connector will be disabled.LAN
Intel I219V
10/ 100/ 1000 Mb/s auto negotiation, Half / Full duplex capabilityIntel I219V
10/ 100/ 1000 Mb/s auto negotiation, Half / Full duplex capabilityCODEC
ALC897
7.1 Channels, High Definition AudioALC897
7.1 Channels, High Definition AudioUSB
4 x USB 3.2(Gen1) ports (2 on rear I/Os and 2 via internal headers)
8 x USB 2.0 ports (4 on rear I/Os and 4 via internal headers)4 x USB 3.2(Gen1) ports (2 on rear I/Os and 2 via internal headers)
8 x USB 2.0 ports (4 on rear I/Os and 4 via internal headers)EXPANSION SLOT
1 x PCIe 3.0 x1 Slot
1 x PCIe 3.0/ 4.0 x16 Slot (x16 mode)
*The PCIe 4.0 only depends on Rocket Lake CPUs.1 x PCIe 3.0 x1 Slot
*The PCIe 4.0 only depends on Rocket Lake CPUs.REAR I/O
2 x WIFI Antenna Ports
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x HDMI Port
1 x VGA Port
2 x USB 3.2 (Gen1) Ports
4 x USB 2.0 Ports
1 x LAN port
3 x Audio Jack2 x WIFI Antenna Ports
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x HDMI Port
1 x VGA Port
1 x DVI-D Port
4 x USB 2.0 Ports
1 x LAN port
3 x Audio JackINTERNAL I/O
1 x M.2 (E Key) Socket: Supports 2230 type Wi-Fi & Bluetooth module and Intel CNVi
2 x USB 2.0 Headers (each header supports 2 USB 2.0 ports)
1 x USB 3.2 (Gen1) Header (each header supports 2 USB 3.2 (Gen1) ports)
1 x 8-Pin Power Connector
1 x 24-Pin Power Connector
1 x CPU Fan Connector
1 x System Fan Connector
1 x Front Panel Header
1 x Front Audio Header
1 x Internal Stereo Speaker Header
1 x Clear CMOS Header
1 x COM Port Header
*M.2 (E key) Wi-Fi card is not provided4 x SATA III Connectors (6Gb/s)
1 x COM Port Header
*M.2 (E key) Wi-Fi card is not providedH/W MONITORING
CPU / System Temperature Monitoring
CPU / System Fan Monitoring
Smart / Manual CPU Fan Control
System Voltage MonitoringCPU / System Temperature Monitoring
System Voltage MonitoringDIMENSION
Micro ATX Form Factor Dimension: 20.8 cm x 23.6 cm ( W x L )
OS SUPPORT
Supports Windows 10(64bit)
*BIOSTAR reserves the right to add or remove support for any OS with or without notice.Supports Windows 10(64bit)
*BIOSTAR reserves the right to add or remove support for any OS with or without notice.BUNDLE SOFTWARE
BullGuard
BullGuard
ACCESSORIES
2 x SATA Cables
1 x I/O Shield
1 x DVD Driver
1 x Quick Guide2 x SATA Cables
1 x I/O Shield
1 x DVD Driver
1 x Quick GuideRead more about Intel H510 series motherboards here:
H510MH/E 2.0: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=1008
H510MX/E 2.0: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=1007
ABOUT BIOSTAR
BIOSTAR, is a professional brand dedicated to the production of motherboards, gaming motherboards, SSD, graphics cards, industrial computing systems, IoT, crypto mining equipment, healthcare solutions and motor start battery. Since its establishment in 1986, BIOSTAR has become a major motherboard supplier in the IT industry. In order to pursue the best quality and aesthetic design, BIOSTAR has invested heavily in ID design, equipment, global marketing research as well as R&D. With a constant emphasis on quality, BIOSTAR always seeks to improve beyond better and race to the future.
Loading new replies...
