Colorful introduced its GeForce RTX 4090 and RTX 4080 Vulcan, Neptune, and NB EX series graphics cards. Built on Nvidia’s Ada Lovelace architecture the next generation of RTX cards is reported to provide massive performance boosts over the current generation. Colorful is also announcing its latest version of iGame Center, providing an all-in-one application for hardware monitoring, overclocking, and RGB control. Availability and pricing have yet to be announced so for now we will have to settle for some brief specifications for each series.
September 21st, 2022 Shenzhen, China – Colorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, introduces its lineup of the next-generation GeForce RTX® 40-Series graphics cards starting with the GeForce RTX® 4090 and GeForce RTX® 4080 models under the Vulcan Series, Neptune Series, and NB EX Series.
Powered by the new ultra-efficient NVIDIA Ada Lovelace architecture, the 3rd generation of RTX, GeForce RTX® 40 Series graphics cards are beyond fast, giving gamers and creators a quantum leap in performance, neural rendering, and many more leading platform capabilities. This massive advancement in GPU technology is the gateway to the most immersive gaming experiences, incredible AI features and the fastest content creation workflows. These GPUs push state-of-the-art graphics into the future.
COLORFUL presents the iGame GeForce RTX® 4090 Vulcan OC-V, iGame GeForce RTX® 4080 16GB Vulcan OC-V, and iGame GeForce RTX® 4080 12GB Vulcan OC-V models featuring a new look and the signature customizable display with a new twist.
COLORFUL also presents the iGame GeForce RTX® 4090 Neptune OC-V, GeForce RTX® 4080 16GB Neptune OC-V and 4080 12GB Neptune OC-V models, also featuring a new look and improved liquid cooling solution. Lastly, COLORFUL also presents the GeForce RTX® 4090 NB EX-V, RTX® 4080 16GB NB EX-V, and RTX® 4080 12GB NB EX-V graphics cards.
COLORFUL will be releasing other models under the ADVANCED Series and ULTRA Series on a later date.
Vulcan Series
Colorful Vulcan Series
The new COLORFUL iGame GeForce RTX® 40 Series Vulcan Series graphics cards feature a new look having many improvements over its predecessor. The new Vulcan Series graphics card features the new Hurricane Scythe Blade – an improved fan blade design that produces more airflow at lower noise levels compared to the previous generation Storm Chaser fan design. The Vulcan model still sports the metallic silver on a black color scheme.
The customizable display is a signature of the Vulcan Series. The new Vulcan Series graphics card features the all-new iGame Smart LCD – a detachable magnetic display. By default, the iGame Smart LCD is installed on the Vulcan graphics card and can be mounted horizontally or vertically. The detachable display can be placed on the included display dock as a stand-alone customizable screen that users can place on their desk. The iGame Smart LCD is connected via USB An included Vulcan Lightboard replaces the iGame Smart LCD on the graphics card when removed and placed on the dock.
The iGame GeForce RTX® 40 Series Vulcan is fitted with two low-key RGB strips that are customizable via the iGame Center. The graphics card adopts a flow-through cooling design that has proven to be more efficient in dissipating heat while at the same time providing better airflow inside the chassis.
Key Features
One-Key Overclock: A conveniently placed button located at the rear I/O that activates overclocking function for a quick and easy performance boost without opening software.
Hurricane Scythe Blades: New fan blade design that delivers a maximum airflow of 55 CFM compared to 42 CFM from previous-generation Storm Chaser fan design.
iGame Smart LCD: A removable magnetic display that can be mounted on the graphics card or on the included display dock. The display has a resolution of 800x216px – fully customizable via the iGame Center app to display real-time monitoring figures, custom images, GIFs, and others.
Display Dock: The display dock is an external docking accessory that users can place on their desk or on top of the chassis that holds the iGame Smart LCD. The display dock connects the display via a USB cable.
Vulcan Support Frame: The Vulcan Support Frame enhances the stability and structural rigidity of the entire graphics card. This eliminates the risk of bending and warping as it supports the weight of the card.
Hollow Back Panel: A hollow back panel design that allows airflow to freely pass-through the heatsink. This design greatly improves heat dissipation compared to conventional GPU air cooling designs.
iGame Accessories: The Vulcan Series comes with a set of accessories including the Screen Wipes, White Gloves, and Screwdriver.
Neptune Series
Colorful Neptune Series
The all-new iGame GeForce RTX® 40 Series Neptune Series graphics cards will be sporting a new look and an upgraded liquid cooling solution compared to the previous generation. The new Neptune Series features a silver and white color scheme. The slim 2-slot graphics card comes with a metal cover with a matte finish – two RGB light strips run through the cover that provides ambient lighting. The RGB lighting is fully customizable using the iGame Center app.
The GeForce RTX® 4090 Series Neptune model graphics card features an all-in-one liquid cooling solution with a 360mm radiator – larger than the previous generation Neptune graphics cards. The radiator is fitted with three 120mm PWM fans with RGB lighting – also customizable with the iGame Center app. Furthermore, the Neptune uses a full-cover copper waterblock that covers the GPU and VRAM.
Key Features
Slim 2-Slot Form Factor: Slim 2-slot PCI thickness that will fit in most PC builds.
Liquid Cooled: Harness the superior cooling performance of liquid cooling for higher overclocks at lower noise levels.
Full-Cover Copper Waterblock: High-performance full-cover copper waterblock that covers the GPU, memory, and other critical components in the graphics card.
NB EX Series
Colorful EB EX Series
The GeForce RTX® 40 Series NB EX model adopt the previous generation design, a triple-fan cooler with an eye-catching Black and Red design. The cooler uses three 98mm fans – all of which feature an upgraded thicker fan blade design.
Redesigned iGame Center UI
Colorful iGame Center
The new version of iGame Center offers more possibilities for hardware-software interaction and a new UI that aims to improve user-friendliness with its intuitive design. Aside from hardware monitoring and tweaking functions, the new iGame Center features a user center for users to register and gain access to exclusive services.
Moreover, the new iGame Center features the OSD Window that allows users to shrink the dashboard into a compact widget that displays vital real-time monitoring information about your graphics card and other components.
Pricing and Availability
For more information regarding the availability of the COLORFUL GeForce RTX® 4090 and RTX® 4080 graphics cards, please contact your local COLORFUL representative.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Today we get a chance to look at one of MSI’s newest cards in their Pascal lineup in the GTX 1070 Quick Silver 8G video card. This GPU isn’t different at all under the hood when comparing it to the MSI GTX 1070 Gaming X 8G we reviewed as far as the upgraded PCB, power phases, and Twin Frozr VI cooler. It’s more of an aesthetic change and to add another option to their Gaming lineup that isn’t in their established red and black color scheme. The Quick Silver version, as you may have guessed, comes in with a black and silver look which matches their latest MPower and XPower Titanium boards really well. Being it is silver and has LEDs, it can fit in with a lot more themes than the regular Gaming X would. We know the looks are different, so let’s get to looking at what else is may be different and see how it passed our testing!
It’s been a long time coming for Overclockers.com, but we’ve finally managed to get our hands on an RTX 3080. For this review, Asus was kind enough to send the ROG Strix RTX 3080 OC along for testing. This version of the RTX 3080 includes a massive ~3 slot cooler to help keep this 320W+ monster running cool and quiet as well as more robust VRMs and slightly higher out of the box clock speeds.
I've had a few Colorful items come across my review table and they've been ok to good products. I can't speak to their warranty or customer service though.
you do a tear down to see the layout of the cards? i was going to get a PNY XLR8 3060ti but wound up getting a EVGA 3070 card. reading around so many said to avoid them, they could never say why. all the video card reviews are of FE/ASUS/GB/Zotac ect cards but i have not seen MSI/PNY. i personally think reviewers should do tear downs to compare the GPU pwm and the memory PWM to other cards.
Many do. Most of ours do.. I couldn't get the 4090 apart easily enough and under a time crunch so it didn't get it. But all of Shawn's reviews tear down. Techpowerup too.
I have not reviewed GPUs but was referring to other components they make like SSDs. I'm not sure if OCF has reviewed any of their GPUs come to think of it. Hmm you could do a search though.
wonder how well this brand is, will they be on the same level as PNY/MSI. could they be more in the GB/Asus/Evga level.
PNY is generally lower shelf than MSI. GB is lower than ASUS/EVGA. I mean depends on what do you expect, but Gigabyte is saving on coolers and power design in way too many models. It's like 1-2 top cards are great, but next couple slightly lower models have cut-down power design and cooling (even though looks the same then has 1-2 heatpipes less or other things like that). MSI does the same as Gigabyte and I would place them on the same level. PNY is like Gainward/Palit/Zotac, so like a lower shelf. Zotac would be higher but they have too many design flaws.
I was only reviewing Colorful motherboards and all were pretty good with a strong power design. However, all had problems with BIOS that wasn't improved later. I saw some graphics card reviews and for some reason all the good stuff is available only in some Asian countries. For the US/EU market they only release mass-sale products.
Most modern graphics cards have a similar power design (except for top OC series). Most are using something similar to reference design regarding power phases or even use full reference design. Most use exactly the same memory chips, no matter what brand. Most differences for end-users are in coolers and warranty terms/support. I wouldn't worry about Colorful PCB/power design. I would only worry about its warranty in some countries.
To follow the other comments about it being a popular brand in Asia.
Ive seen some pretty cool looking and popular pieces of gear by colorful but most of those posts are coming out of Asia.
I am curious to see if they will make a play to try and pick up some of the gap EVGA leaving the US market created.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
Loading new replies...
Senior Forum Spammer
Gulper Nozzle Co-Owner
Benching Team Leader
Has slightly less legible writing than Thideras
