COLORFUL Launches GeForce RTX 3060 Ti Series Graphics Cards
Colorful launched a new line of RTX 3060Ti graphics cards on December 1st. There are a total of four cards in this series, the flagship iGame GeForce RTX™ 3060 Ti Vulcan OC 10G-V,  iGame GeForce RTX™ 3060 Ti Advanced OC 10G-V, iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V, and GeForce RTX™ 3060 Ti Ultra W OC 10G-V. They share the same 4864 CUDA cores, 1410 MHz base clock, and 8GB of GDDR6 memory. Boasting boost clocks of up to 1815 MHz is what separates the Vulcan from the others, each achieving a slightly different boost clock. Naturally, aesthetics are another major variation. A complete list of specifications and pricing are listed below.
December 1st, 2020 Shenzhen, China – Colorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, proudly introduces the COLORFUL GeForce RTX™ 3060 Ti Series graphics cards. COLORFUL’s line-up consists of the Vulcan, Advanced, Ultra, and the new Ultra White Series models, each of which come with a different set of premium features to cater to different types of gamers and PC enthusiasts.
NVIDIA Ampere Architecture
Powered by the NVIDIA Ampere architecture and the 2nd generation of NVIDIA RTX, the world’s most powerful PC gaming platform for real-time ray tracing and AI, the GeForce RTX 3060 Ti delivers blistering 1080p and 1440p gameplay starting at only US$399.
The GeForce RTX 3060 Ti supports the trifecta of GeForce gaming innovations including performance-accelerating and IQ-enhancing NVIDIA DLSS technology which is now available in over 25 games; NVIDIA Reflex which reduces system latency (‘input lag’), making games more responsive, and giving players in competitive multiplayer titles an extra edge over the opposition; and NVIDIA Broadcast, a suite of audio and video AI enhancements including virtual backgrounds and noise removal that users can apply to chats, Skype calls and video meetings.
Whether you are playing traditional PC titles, powering through creator and productivity workflows, or marveling at the latest cutting-edge ray-traced titles like Cyberpunk 2077, Call of Duty: Black Ops Cold War, Watch Dogs: Legion, and more, the GeForce RTX 3060 Ti delivers the best possible experience in its class for everyone, everywhere.
COLORFUL iGame GeForce RTX™ 3060 Ti Vulcan OC-V
The COLORFUL iGame GeForce RTX™ 3060 Ti Vulcan OC-V features an LCD screen that can display GPU status and monitoring tools such as GPU temperature, Core Clocks, and others. Also, it can display the picture you uploaded. Like the other 30Series, the LCD can be flipped 90° to make the LCD screen visible even in vertical graphics card mounting orientation. The RTX™ 3060 Ti Vulcan features the new 13-blade cooling fan design and the iGame Vacuum Copper Plated Technics that delivers superb heat dissipation for stable overclocking. It also comes with the One-Key Overclock – a straightforward overclocking feature that delivers an instant performance boost to 1815MHz in just one push of a button.
iGame GeForce RTX™ 3060 Ti Vulcan OC-V Specifications
GPUGeForce RTX 3060Ti
CUDA cores4864
Base Clock/Boost Clock1410/1665 MHz
(Turbo Model) Base/Boost Clock1410/1815 MHz
Memory Config8GB
Memory InterfaceGDDR6
Bus width256Bit
Power connector3x 8-pin
Graphics Card Power200W/230W
Graphics Card OC Power240W/320W
CoolingTriple Fans
5x 8mm⌀ heatpipes
Dimension (L x W x H)425mm x 277mm x 118mm
COLORFUL iGame GeForce RTX™ 3060 Ti Advanced OC 10G-V
The COLORFUL iGame GeForce RTX™ 3060 Ti Advanced OC features a premium shroud with a metallic finish that diffuses the central fan “Energy Core” lighting to give it a sophisticated and mysterious “Light Frozen” lighting effect. The triple-fan cooling solution includes a high-performance heatsink with four 8mm-diameter heat pipes that deliver aggressive heat dissipation. The RTX™ 3060 Ti Advanced OC also features the One-key overclock for a quick performance boost to almost 1800MHz.
iGame GeForce RTX™ 3060 Ti Advanced OC 10G-V Specifications
CUDA cores4864
(Turbo Model) Base/Boost Clock1410/1800 MHz
Memory Config8GB
Bus width256Bit
Power connector2x 8-pin
Graphics Card Power200W/220W
Graphics Card OC Power240W/260W
CoolingTriple Fans
4x 8mm⌀ heat pipes
Dimension (L x W x H)378mm x 243mm x 103mm
COLORFUL iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V
The COLORFUL iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V is designed to fit the lifestyle of gamers with its “Vaporwave” colorway. It gives a feeling of nostalgia with its classic color theme of light and bright colors. The iGame GeForce RTX™ 3060 Ti Ultra features a triple-fan cooler with two 90mm and one 80mm cooling fan. The heatsink has four integrated heat pipes, two 6mm-diameter and two 8mm-diameter heat pipes that deliver aggressive heat dissipation. The fins are connected using integrated reflow soldering, an advanced process that creates high-quality soldering compared to traditional methods.
iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V Specifications
CUDA cores4864
(Turbo Model) Base/Boost Clock1410/1770 MHz
Memory Config8GB
Buswidth256Bit
CoolingTriple Fans
2x 8mm⌀ heatpipes + 2x 6mm⌀ heatpipes
COLORFUL GeForce RTX™ 3060 Ti Ultra W OC-V
COLORFUL introduces the new White version with the COLORFUL iGame GeForce RTX™ 3060 Ti Ultra W OC. Like the Ultra Series, Ultra W sports an all-white color theme with its white shroud, fans, and backplate. It uses a triple-fan cooler for fast heat dissipation to maximize performance. The cooler uses two 90mm and one 80mm cooling fans. Its high-performance heatsink has two 6mm-diameter and two 8mm-diameter heat pipes connected to the fins using integrated reflow soldering, an advanced process that creates high-quality soldering compared to traditional methods. iGame GeForce RTX™ 3060 Ti Ultra W with its Ultra White color is perfect for all-white gaming PC builds for perfect color matching for a neat and uniform white gaming PC.
iGame GeForce RTX™ 3060 Ti Ultra W OC 10G-V Specifications
CUDA cores4864
Memory Config8GB
Buswidth256Bit
CoolingTriple Fans
Learn more about the COLORFUL GeForce RTX 3060 Ti Series graphics cards on the Colorful home page: https://en.colorful.cn/
Pricing and Availability
COLORFUL iGame GeForce RTX™ 3060 Ti Vulcan OC 10G -V: $599
COLORFUL iGame GeForce RTX™ 3060 Ti Advanced OC 10G -V: $519
COLORFUL iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V: $479
COLORFUL GeForce RTX™ 3060 Ti Ultra W OC 10G-V: $479
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,230 messages 225 likes
Colorful launched a new line of RTX 3060Ti graphics cards on December 1st. There are a total of four cards in this series for Colorful with the iGame GeForce RTX™ 3060 Ti Vulcan OC 10G-V being its flagship. The other three consist of the iGame GeForce RTX™ 3060 Ti Advanced OC 10G-V, iGame GeForce RTX™ 3060 Ti Ultra OC 10G-V, and GeForce RTX™ 3060 Ti Ultra W OC 10G-V. They share the same 4864 CUDA cores, 1410 Mhz base clock, and 8GB of GDDR6 memory. Boasting boost clocks of up to 1815 Mhz is what will separate the Vulcan from the others, each achieving a slightly different boost. Naturally, aesthetics are another major variation. A complete list of specifications and pricing are listed below.
Click here to view the article.
Reply Like
