EVGA X79 Dark Motherboard Review
Every now and then a company has to invest in fixing its image. EVGA has had a decent run the last couple years with its motherboards, but they have had issues, mostly with the BIOS. The boards have been solid, but the BIOS has been a) behind, without a decent UEFI to speak of and b) buggy with a capital B.
Even when they’re not too bad (see our EVGA Z77 Stinger review), they have bugs. In that case, an inability to run RAM at the speeds it’s capable of. Aside from that it was a solid board, but it was an issue that should have been fixed. Still to this day it has trouble running high speed RAM and the BIOS has been updated only once since that review.
So, EVGA has a small but noticeable blemish on its reputation – its BIOSes have been buggy and their lack of updates make one wonder about the support you’re getting from the BIOS team. The last very solid, nearly flawless board they had was the X58 Classified.
EVGA’s most public overclocking face – Vince “k|ngp|n” Lucido – has said they’re going to change all of that, starting with the EVGA X79 Dark. In a post at the Kingpin Cooling Forums, he basically admits that recent EVGA boards haven’t been up to snuff (“…an older resource scarce interim engineering team that well, lets just say wasn’t making the boards the best they could be.”) and says they’ve turned the page on that book. “EVGA put together a different engineering team and brand new bios team to make better boards =/> than X58 CLASSIFIED.” Further, “Along with titan and soon 780, it now holds almost every single major modern benchmark world record.”
The X58 Classified left some big shoes to fill. It was the premier X58 motherboard. Saying the Dark is equal to or even greater than that board is a big statement. Today we dig into the Dark and find out what EVGA has done – and whether it is able to fill those large, if aged, shoes.
Packaging & First Look
EVGA goes simple with packaging and that can be a good thing. It’s what’s inside that counts. The board is well protected and all the relevant specs/features are right on the box.
EVGA X79 Dark Box
EVGA X79 Dark Box
Ahh, the X79 Dark. We’ll get the board photos out there first thing. This board is dead sexy. Aside from minimal red highlights, it is all black, befitting its Dark name. EVGA kindly includes several stickers to indicate RAM positioning and voltage warnings as well as a handy little instruction manual for inserting a CPU in the 2011 socket.
EVGA X79 Dark With Stickers
Now that those stickers are off, let’s look at the board itself. I really like this look; plain and powerful looking.
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
EVGA X79 Dark
Ok, so we know it looks good, let’s find out what it’s made of.
Specifications & Features
EVGA doesn’t give massive specification lists, they just list the Very Important items and let their products do the talking. These specs & features are pulled from the X79 Dark product page.
Specifications
Performance
  • Based on Intel X79 chipset
Memory
  • 8 x 240-pin DIMM sockets
  • Maximum of 64GB of DDR3 2400MHz+
Storage I/O
  • 6 x Serial ATA 300MB/sec (4x Internal + 2x E-SATA) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
  • 6 x Serial ATA 600MB/sec (6x Internal) with support for RAID 0 and RAID1
Expansion Slot
  • 5 x PCIe x16/x8, 1 x PCIe x4
Multi I/O
  • Audio connector (Line-in, Line-out, MIC)
Integrated Peripherals
  • 8 Channel High Definition (Realtek ALC898)
  • 2 x 10/100/1000 (Intel 82579/82574)
Form Factor
  • E-ATX Form Factor
  • Length: 12in – 304.8mm
  • Width: 10.375in – 263.5mm
Features
  • Intel X79 Express Chipset
  • Triple BIOS Support
  • 8 Channel High Definition Audio + Optical
  • EZ Voltage Read Points
  • 12+2 Phase PWM
  • Onboard CPU Temp Monitor
  • PCI Express 3.0 Ready
  • CLEAR CMOS, Power and Reset
  • E-LEET Software Support
  • Dual 8 Pin CPU Power
  • EVGA EVBot Support
  • PCIE Disable Switches
Accessories
Aside from the board, there are plenty of accessories accompanying it. As this was a before-IVB-E release, the two primary BIOSes (there are three) had SNB-E BIOSes, but the third one gives instant IVB-E compatibility. Of course, any time there’s a new CPU out, you’ll want to update that BIOS to the latest release ASAP.
There is alo your standard EVGA fare – motherboard manual, driver disc, case badge & board quick-reference poster.
Instructions, Driver CD, Case Badge
BIOS Notice for Ivy Bridge-E
There are three SLI bridges included, for two, three and four-way SLI. There is also an I/O cover that makes the board look even better when it’s mounted in a case (or on a bench).
SLI Bridges
SLI Bridges
Internal Rear I/O Cover
In case the plentiful USB options on the rear I/O aren’t enough, you get four additional USB 2.0 and two additional USB 3.0 ports via included PCIe brackets.
The rear I/O cover is (as usual) self-explanatory. They have also included an alternate socket backplate in case your chosen heatsink/water block/extreme cooling pot don’t take advantage of the built-in socket 2011 screw holes.
USB 2.0 & USB 3.0 Brackets
Rear I/O Plate & X79 Backplate
There is plenty of cabling included, with two SATA 6Gb/s and two SATA II cables and two MOLEX-to-SATA power adapters, one of which is even sleeved.
On the right you can see the plug for monitoring voltages via multimeter probes (which can just be plugged in and forgotten thankfully). There are also four included GPU Link wires. Looking around for documentation, it’s a little sparse for the time being, but these are designed to control certain aspects of your GPU (i.e. GPU voltage, vMEM voltage, etc) from inside the board’s BIOS. They are intended for advanced users who aren’t afraid to manually solder wires onto their GPUs to link them to the board.
Wiring Accessories
Wiring Accessories
Monitoring Wires
Monitoring Dongle & GPU Link Wires
There are definitely plenty of accessories to get the board up and running. I might want a few more SATA cables, at least enough to fill up the ports because most people are going to buy one board and won’t have an extra six SATA cables on-hand. Aside from that minor shortcoming, everything is solid.
Up Close & Personal
Now it’s time to get up in the Dark’s grill, so to speak.
EVGA X79 Dark
EVGA X79 Dark
The back side of the PCB is as you’d expect the back side of a PCB to look, clean and without any bad soldering to be seen.
Board Rear
Board Rear
The front side is where the action is, starting with the now almost two year old Socket 2011. Intel didn’t change anything here and the retention mechanism is the same two-lever hold-down that’s needed for such a large CPU.
Socket 2011
Socket 2011
There are dual 8-pin CPU power inputs on the Dark for pushing your CPU to the absolute max under extreme conditions.
Dual 8-pin CPU Power
In the far upper left of that photo you can see the header where you plug in the ProbeIt dongle. Neither the plug nor the wires are labeled (there isn’t really room), but thankfully EVGA has a helpful diagram.
Probeit Diagram
Probeit Diagram
In the upper right of the board resides your control center. Here you’ll find onboard power, reset and clear CMOS buttons, the POST code indicator, the CPU fan header and ports for the GPU Link wires seen earlier.
Control Corner
Control Corner
Moving a little further down you can see EVGA’s exclusive 90° 24-pin ATX power connector. This can be a blessing or a curse, depending on how close your case’s wire management hole is. Just to the left of the connector you can see the removable BIOS chip socket and toggle switches for disabling PCIe lanes. These are very useful for troubleshooting when you’re running multiple GPUs and for running multi-GPU configurations when benchmarking. Unfortunately they reside underneath the first GPU, so their usefulness is hampered significantly.
BIOS Chip, Perpendicular Power, PCI Switches
There are plenty of I/O connectors on the bottom of this board. Left-to-right we have the 6-pin PCIe supplemental power (highly recommended for running this board), front panel audio connection, onboard speaker (many boards don’t have those now-a-days; it’s handy to have audio confirmation of POST), two fan and two USB 2.0 headers, followed by the USB 3.0 header, front panel switch headers, yet another fan header and the triple BIOS toggle switch. To its right, there is yet another fan header!
Left Bottom Connectors
Left I/O Connectors
Right Front I/O Connectors
Right I/O Connectors
Moving in a little closer, you can see EVGA went with ASMedia’s ASM1042 USB 3.0 controller.
ASMedia USB 3.0 Controller
There are plenty of storage connectors on this board.  There are six SATA 6 Gb/s ports and four SATA II ports. The six 6 Gb/s ports are split between two native SATA 6Gb/s ports and four controlled by a Marvell 88SE9320 SATA 6 GB/s controller.
Internal Storage Connectors
Marvell SATA 6Gb/s Controller
Continuing our controller tour, the rear I/O uses another Marvell controller for the two eSATA (SATA II) connectors and another ASMedia ASM1042 for the four rear USB 3.0 ports.
Marvel eSATA Controller
Audio comes courtesy of Realtek’s ALC898 and LAN courtesy an Intel controller.
Intel LAN Controller, Realtek Sound
There is plenty of connectivity on the rear I/O. You have built-in bluetooth, six USB 2.0 ports, four USB 3.0 ports, dual LAN and your standard digital/analog audio out. Additionally on the left are a port for EVGA’s EVBot as well as another clear CMOS button, which is very handy since you can use it to clear CMOS with your board inside a case.
Rear I/O
Rear I/O
Under the Hood
Removing the heatsinks the X79 Dark gets even Darker, losing its read highlights present on the heatsinks.
EVGA X79 Dark - No Heatsinks
EVGA X79 Dark – No Heatsinks
Speaking of heatsinks, contact was good and the heatsinks seem to do their job well, wicking away and dissipating the heat without issue. It was nice to see normal thermal paste on the PCH heatsink too, as opposed to that horrid stuff ASUS uses.
Heatsink COntact
Heatsink COntact
Both heatsinks have red accents and both look good. They fit the board well, giving it a splash of color in an otherwise nondescript, mostly black motherboard.
PCH & PWM Heatsinks
PCH & PWM Heatsinks
PWM Heatsink
PWM Heatsink
Here we have the now somewhat aged X79 platform controller hub (PCH). It’s not EVGA’s fault the PCH is old, that’s all on Intel. They’re doing the best they can with the hand they’re dealt, adding the necessary controllers to compensate for what the X79 PCH lacks.
X79 Platform Controller Hub
The power section on this board is a thing of beauty. Those dual 8-pin CPU headers (only one is required for operation) feed a very strong twelve-phase CPU power section. There is plenty of power here to torture your CPU, whether it’s on air, water or liquid nitrogen pushing crazy voltages at or near 2.0 V.
Power Section
Power Section
Power Section
Power Section
EVGA X79 Dark Power
EVGA X79 Dark Power
EVGA X79 Dark Power
EVGA X79 Dark Power
The board itself is killer, no doubt. That hasn’t ever been EVGA’s problem. Their boards from a hardware standpoint have been impeccable for years now. The X79 Dark is no different and is built like a tank.
The UEFI
The BIOS, however, has been EVGA’s Achilles heel in recent years. They know it and they have been working to fix it. With the most recent public release for Ivy Bridge-E, I’m happy to say EVGA has done just that. Aside from a couple minor annoyances (like reporting higher-than-received CPU voltages, which you can monitor with a multimeter anyway), the X79 Dark’s BIOS is ready for prime time and rock solid stable.
When you first go into the BIOS, EVGA doesn’t mess around, dropping you into the Overclock menu, where you can tweak and overclock your CPU & RAM to your heart’s content.
Overclock Menu
Overclock Menu
Overclock Menu
Overclock Menu
The CPU Menu gives you every option you could ever want with regard to CPU power saving, thermal management and power control.
CPU Menu
CPU Menu
CPU Menu
CPU Menu
The Dark has plentiful RAM timing options, allowing those that tweak sub-timings to go to town. There are even several RAM presets for use in tweaking RAM with certain ICs.
RAM Timings
RAM Timings
RAM Timings
RAM Timings
The fan control leaves a bit to be desired. It’s there, but isn’t necessarily all that extensive. EVGA is a bit behind in fan control, especially when you consider ASUS’ FanXpert and its control over both 3-pin and 4-pin fans.
Voltage Monitor & Fan Control
In the Save & Exit menu, there is one feature of note – the ability to save up to eight BIOS profiles.
Save & Exit Menu
Save & Exit Menu
The rest of the BIOS is pretty standard fare and we won’t do much in detail here; you can check out the rest of the screenshots in a slideshow below. One thing noticeably missing is the ability to update the BIOS from within the BIOS itself. You have to either make a bootable USB thumb drive with DOS, or update from within Windows. I chose the latter and have done so several times without issue – just be sure you do so with a completely stable system! Crashing during a flash would be catastrophic for that BIOS.
EVGA Software
With its simplistic looks based on the very well known CPUz software, E-LEET is about as easy to use as it gets. It has everything but fan control (which is the one thing EVGA is very lacking on).
The first three tabs are pretty standard CPUz type fare, showing the same system specs you’ve come to expect out of CPUz over the years.
EVGA Eleet
EVGA Eleet
EVGA Eleet - Motherboard Info
EVGA Eleet – Motherboard Info
EVGA Eleet RAM Info
EVGA Eleet RAM Info
The fourth tab starts to look like its own software, with plenty of monitoring – voltage, temperatures & fan speeds are all present and accounted for.
EVGA Eleet Monitoring
The overclocking and voltage tabs are arguably the most important in the program. Everything you need to push your system from within windows is right here in an easy to use format.
EVGA Eleet Overclocking
EVGA Eleet Voltage Adjustment
Last up, we have the processes and options tabs. In processes you can set different programs’ affinities to various cores. This could be useful to distributed computing buffs as well as benchmarkers. Most folks won’t use it, but it’s a nice value add for those that will. The options tab has a couple small options but the big takeaway from this tab is the overclocking profiles.
EVGA Eleet Thread Prioritizing
EVGA Eleet Affinity
EVGA Eleet Profiles
EVGA Eleet Profiles
Eleet is a solid overclocking program on a solid motherboard. The only thing missing is fan control. To me that doesn’t matter – I always use separate fan controllers – but some people don’t have that type of control and motherboard fan control is a must have. This is the one area where the Dark (and, indeed, pretty much all of the EVGA motherboard lineup) is lacking. Aside from that, you won’t see any complaints about Eleet from me.
Overclocking for Stability
When overclocking our i7 4960X sample, it made it to a respectable 4.6 GHz, fully stable. You saw that in the 4960X review though, so it’s no surprise.
Dark @ 4.6 GHz / DDR3-2400
There won’t be any comparison benchmarks today; you already saw all of them in the Intel i7 4960X – Ivy Bridge-E CPU review. We left out a Pushing the Envelope section though, because the early beta BIOS needed a little tweaking. Verison 2.04 fixed everything and allowed us some more headroom.
With the most recent, ready for primetime release BIOS (version 2.04), EVGA has improved the PLL overvoltage option and allowed greater overclocks. Using this BIOS on water cooling, I was able to push our CPU to 4.8 GHz for multi-threaded WPrime testing.
WPrime 32M @ 4.8 GHz
WPrime 1024M @ 4.8 GHz
Even better, it was able to run single-threaded SuperPi testing at 4.9 GHz.
SuperPi 1M @ 4.9 GHz
SuperPi 32M @ 4.9 GHz
Last, but not least, we were able to validate the CPU at 5.0 GHz before the OS crashed and burned.
5011 MHz Validated
5011 MHz Validated
Validation Link
Final Thoughts & Conclusion
There is a lot to like about this motherboard. The most obvious is its look. While totally subjective, personally this board is one of the best looking boards I’ve worked with. It screams power and has just enough red accents on the heatsinks to make it pop. Two thumbs up for aesthetics.
The X79 Dark is also built like a tank. From the plentiful power input connectors (dual 8-pin CPU and supplemental 6-pin PCIe bus power, which is very well placed I might add) to the strong, 12-phase power section those 8-pin connectors feed, this thing is built to beat up on your CPU.
The biggest sticking point with EVGA boards of late is their BIOS. I’m happy to report, in this reviewer’s opinion, they have gone over and above to address their past issues. This new UEFI looks great, it’s rock solid stable, it has everything you need to push your system to the limit and it allows you to overclock as far as your CPU and cooling will let you. The only hiccup is voltage monitoring and you can use a multimeter if total accuracy is important to you. Their new BIOS team is strong and doing a great job with this board.
Of course, all this goodness will cost you. The EVGA X79 Dark retails for $399.99 on Newegg. As feature-packed, extreme-oriented X79 motherboards go, that’s not too bad. ASUS’ Rampage IV Extreme costs $429.99 and nobody knows what the Rampage IV Black might cost when it comes out. So the Dark, while expensive, is priced where it should be.
At the beginning of the review, I mentioned that legendary overclocker Vince “k|ngp|n” Lucido said this is the rebirth of an X58 Classified-style, take no prisoners motherboard. You can see his phenomenal results on HWBot using the X79 Dark (and a golden 4960X CPU) – #1 in the world in 3DMark Vantage & #1 in the world in 3DMark 11 are two good examples. After using it for the better part of a month in testing out Intel’s latest CPU, I’m inclined to agree.
Overclockers_clear_approved
– Jeremy Vaughan (hokiealumnus)
About Jeremy Vaughan 197 Articles
I'm an editor and writer here at Overclockers.com as well as a moderator at our beloved forums. I've been around the overclocking community for several years and just love to sink my teeth into any hardware I can get my paws on!
Discussion
Leave a Reply
Your email address will not be published.
  1. Excellent review - actually made me want to go out and get one. Does look good too - even the BIOS screenshots. Too bad about the fan controls - Maybe EVGA is thinking that people will be using hardware fan controllers?
    The price seems about right too. Mircocenter even has it $380.00 when bundled.
    Have you tested the RIVE and Dark head to head with Ivy-E? I'd like to see same Ivy-E chips tested on both boards to compare max clocks on air/water to see if the Dark's BIOS has matured enough yet to give it an edge or if it holds back the chip.
    Also, I'd like to see power consumption tested between the two boards under load when overclocked to 4.5-4.6Ghz. This review here showed a 36w difference at stock load in favor of the Dark, as much as the difference between SB-E and Ivy-E chips:
    http://www.ocaholic.ch/modules/smartsection/item.php?page=7&itemid=622
    Sorry, the RIVE is in my 24/7 machine and isn't easily interchangeable, so I haven't been able to test them against each other (nor do I want to update to an IVB-E BIOS since it runs the 3960X). However, fear not - I am working diligently to ensure we get a Rampage IV Black when they launch and we'll definitely have head-to-head testing. We don't typically do power consumption tests for motherboards, but I'll try to remember to run that in addition to the benchmarking gamut. :thup:
    Several of them, but there were a lot of complaints about the X79 Classified - so much so EVGA offered to 'upgrade' people to the Dark for a fee.
    The Z77 Stinger I have still won't run memory north of 2133 and it's pulling teeth to get it to even run that. There has been exactly one BIOS update since its review published (despite assurances to the contrary, which is why I gave it a pass, being told it would be resolved) that didn't do a thing for it.
    The P55 FTW was also pretty well known for killing CPUs, anecdotally speaking.
    Be sure to let us know what you think DevilDog!
    CORRECTION
    I had to correct the Probeit diagram and have done so. Since this board has multiple VDIMM voltages, things were switched around a bit. Here is the corrected diagram, which has also been fixed in the review:
    FYI, I was just emailed a fixed BIOS that's supposed to have stock operation working as it should. I'll update after I get the chance to test, hopefully this week.
    Well, got to play with it a bit today. Good to see EVGA is heading back in the right direction. The one thing that I do see and they have been able to replicate is that XMP is borked. Can't run anthing so far when an XMP profile is selected. Not a biggie for me as I like to set mine manually.
    I'm liking the 4820k as well. The force seems strong with this one. I'll have more time this weekend to play with it and will update.
    Let is know how that bios turns out Hokie.
    hokiealumnus
    I'm happy to report the new BIOS fixes the stock turbo issue, so that's all set. :thup:
    The beta is uploaded to our servers and you can download it here. Remember, it's a BETA and you use it at your own risk.
    Thanks brother.:thup: I'll give this one a shot. Tonight or tomorrow.
