Well, I did some figuring during breakfast: the monitor has a black-to-white refresh rate of 16ms. 1000ms = 1s, so 1000ms/16ms = 62.5 times-per-second, or roughly 60 times-per-second, which is what the max Hz rating happens to be (60Hz). So, the monitor is able to, at max, refresh 60 times-per-second, making it perfect for 60fps feeds. So, why in the hell would it start to smudge at only 30fps? Answer: the GPU. If the GPU can't keep up with the render, it would be unable to fill in the areas where another color just was, thusly giving a "smudge" effect (like I was getting). Now, with my 7900GS, un-OC'd, it's slightly there, but what this does tell me is that G92 will make this monitor shine. AKA: I got something to look forward to
. So, in a nutshell: this monitor is kickass, no doubt about it; I strongly recommend a GPU at, or above, par with a 7900GS for best results, however. For even better results: pick up a noise-insulated DVI cable, if you really want to go OCD. I will be running more tests over the next few days, so don't let this thread expire just yet
-Mobious-
PS:
