If you have a locked Barton, and have a digital multi-meter, and would like to spend an hour or so to do some measurements and test, it may help to close this possibility, either positively or negatively.
Are there any hidden multiplier pins from the NC, VCC, VSS pins?
The main idea is to see
1. Whether there are some VCC or VSS pins, measured from VSS, have large resistance, say, > 100 ohm. Normal VCC to VSS should be much smaller, and of course normal VSS to VSS should be zero.
2. Whether there are some NC pins, measured from VSS, have relatively small resistance, say, < 10 M ohm.
3. All resistance measured from VSS is sufficient, at least for the first trial.
4. In principle, ONLY measuring VCC, VSS and NC pins from VSS is sufficient. But if one can find someone to help, may well just measuring every pins and put the resistance number from VSS in the pin layout map and analyse them after the measurement.
AMD pin layout map, on Page 55
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26237.PDF
If suspecting there are some hidden pins (not specified in data sheet) among the
- NC pin group, or
- VCC pin group, or
- VSS pin group,
one can make a
resistance map or table of each pin to VSS, and look for difference.
With a probe of a DMM connected to VSS, measure the resistance of each pin to VSS, and make a table. Then compare the resistance table to the pin table. One may want to measure each pin twice with the polarity reversed.
It should not be too difficult to do, especially if one can find a helper to write down the numbers while doing the measurement.
If a pin can be measured in 4 sec, a single pass of 478 pins would take about 32 minutes. Two pass would be about an hour.
If there is/are multiplier controlling pin(s) hidden among these NC, VCC, VSS pins, the resistance of that pin(s) would
standout differently from the other regular NC, VCC, VSS pins.
- If a pin is not a VCC pin or a VSS pin, and if it goes to the input of logic gates, or FET terminals, even if there is pullup or pulldown impedance, would be >> 10 ohm.
- If a NC pin turned out to be not NC, then the resistance would be much smaller than 10M ohm.
Have to set the DMM resistance to x1 or the lowest setting, and keep it that way, so that the setting and biasing point from the DMM to the pins remains as constant as possible.
I check a few NC, VSS, VCC pins using a 1800+.
- The resistance from VCC to VSS should be very low, of the order of 10 ohm or less (exact number depending on the DMM) and polarity. It should be similar for locked and unlocked Barton.
- Also the NC pins, if indeed is NC, should have very high impedance (>> 10M ohm).
