Okay, here's the scoop on the possible existence of a second set of pins. I have spent the past three evenings ohming the 5 known BP_FID pins on my unlocked Barton to all the other pins on the bottom and sadly, though not unexpectedly, I must report that none of the other pins, regardless of claimed function, be that Vss, Vcc, N/C, etc, are connected to them.
Now, here's where it gets "creepy". I eventually snapped and did something I never dreamed I would do. On the Locked Barton, I heated the core with a micro hydrogen flame torch, to keep the heat locallized to the core until the sealant around the edge softened, as well as all the solder dots, be they bismuth, indium, or whatever low temperature metal AMD uses, melted. I then lifted the core off the carrier.
Yes, we're talking CPUicide here. Following the traces from the L3 bridges to their destination solder dots in the array on top of the carrier, beneath where the core sits and the dots leading inside it touch, I discovered they were actually connected to the core's corresponding dots just like all the other traces.
That shoots down my theory about the paths leading to the multiplier control circuitry having been etched back, cut, or whatever, before the core was mounted onto the carrier.
So where does that lead us, other than recommending me for committment to an appropriate institution? Either, as some of you have proposed, they gave those circuit inputs a lethal shot of current or there may be some microcode embedded inside the core which can be programmed to ignore the input logic levels to the multiplier control circuitry. I seriously doubt the cores themselves are different, though I'm certainly not going to trash my remaining unlocked Barton to compare them. I'm already having enough difficulty dealing with my self-loathing, not to mention the $90 price tag to satisfy my curiousity.
Score: AMD 1, OC'ers 0
I'm bushed after three nights of late hours and am off to the refuge from my deed, known as sleep.
Just in case anyone who both appreciates the sacrifice and has a real job want to help out, I'm not too proud to accept contributions.
Hoot the Horrible
