- Feb 20, 2015
Hey, So here is my PC spec:
7700k
Msi z270 Tomahawk
2x8GB DDR4 G.Skill 3000 mhz Cl15
Gtx 1080ti Titan Gaming x MSI
SSD 850 Samsung EVO
And here is what happend:
I turned on my PC today, and it was working for around 20 minutes.
After it he shuted down.... Just turned off.
When I tried to reset it/Turn On the MOBO LED blinked on "CPU" line...
I started to unplug not usefull things like: Coolers/Graphic Card/1 kit of memory/ SSD.
I tried to start PC again, and actually he did...
I got an warning that Graphic card/memory RAM changed,but then i went to BIOS....
Because cooler was off it was at 3,2GHZ [before i was running it on 4.8 GHZ] and PC was working for around 2-3 minutes,then he SHUT down again and...the CPU LED started to blink again..
I unistalled all comonents from the PC tower,and here is what I've noticed:
THE MOBO [msi z270] stinks...but it stinks around DVI slot.... wich is werid, I never use it even once...I'm using HDMIcable...
the CPU looks fine, i don't see any black points on it, he dosent stinks or so on...
And here is my question:
Would you suggsed me to send back all components to the Vendor and tell him to check it out, or just the MOBO+CPU? What you guys think about it?
7700k
Msi z270 Tomahawk
SSD 850 Samsung EVO
