By some simple math to keep all pressure equal "in a completley sealed case" you would need 2 120 mm fans moving 400 CFM each or a little less because depending what tubing you use you will get obstructions in airflow and if your duct is right over the HSU then it may not be able to draw 800 cfm , and it was in a car right? All cars if in not mistaken un on a 12v system so any car part you get should run on 12V
- boo
- boo
