- Nov 12, 2002
- Rootstown, OH
Inserted a code snippet using noparse tags - otherwise no one can copy from the contents of your quote.
while i understand your meaning i still think its not visual enough.
i do a demonstration with a stove 2 pans a bucket of ice water and a hose going from the tap into a pan.
Impingement/turbulence - that's it in a nutshell.Faster water over a CPU block pins increases the interaction of water molecules (impingement/turbulence?) For example, ...
One simple way to conceptualize it is to think about a sand-blaster removing paint from a metal or concrete surface. The sand is the water molecules and the paint is the heat in the water block. Of course, in the case of water-cooling the paint keeps coming back. Still, it's a common, graphic example of impingement as it's meant in water-cooling ...
If someone builds a loop wrong it IS a horror show!I dig your example with sandblasting, very perfect. And "The paint keeps coming back" is like a horror movie or something like that, made me chuckle.
Sometimes I think we are on the same wavelength QuietIce, except my ice makes noise in my glass.
Aha, you mean this I think thorilian.
http://www.overclockers.com/forums/showpost.php?p=6332602&postcount=4
We close to stickying this? Last comments?
IMOG and Hokie etc?
