My A7N8X defaults to 100FSB everytime I cold boot. I go into the bios and my settings are all there, so I just have to press F10 and exit. It's weird. I do not like Asus.
Arkaine23 it's an old problem that many have expienced and some have cured.... you're voltage is too high for the motherboard to handle i would think.... you could also try replacing the lithium battery on the board(i'm sure you have already tried this though)
Try cutting the power with the plug or rocker switch then when you turn it back on press and hold the insert key while you press the front panel power button. It should boot up with safe settings if you do not fix the problem it will still not boot when you try rebooting normally.
