well i got my abit sd7-533 back.after they got my bad m.b,in 2 days they sent me another m.b.i got it june 7th.i sent them a msg also to as why the cpu temps run to high,and for them to please look into this matter.wheather they do or not.i don't know.
..i may have to many fans in here,which im checking in these forums for ideias..the cheap case i have 92mm fans 2 wire will mount,they are 50cfms.and the 120mm 3 wire 92 cfms im gona try 3 wire 80mm,2 in the frount and rear,rear being exuast,which 2 80mm at 37 cfms,will be 74 cfms.i looked at some lian li case setups,
which im gona buy one with a watercooling setup.im getting my credit card paid down pretty fast
even though the lian case i think have more cfms,useing 2 80mm front and rear,and a top 120 mm fan,and the side fans,im new to modding cases,but im learning..
i had my ethermax 431 watt power supply mounted on the out side of the case,its a steel case,it took up room,haveing it inside,im gona put it back inside,i have 2 fans 120mm,and a 92 mm in the top.one fan in the back side,2 on the frount panel.worked good with my asus p4s333 m.b useing the p4533 bios.plus too i ran a 3 inch flex metel round pipe from the cpu to the outside of the case,im gona do the same with the abit m.b.
i used cardboard on a 120mm fan to suck air off the heat sink,which is a volcano 7+
now back to the abit setup,which i have digital doc 5,in this case
now i have a new siftech mcx478 heat sink with fan.that should help,running a flex duct off it to the outside of the case,which im gona run through the wall to the outside,its summer now,then run a 3 inch flex from one of my vents off my main duct for a/c,covering half the vent
,that will help alot,on cooler days,i can use the flex duct runnning to the out side,of course with a pice off screen,so no bugs fly in,and a homemade filters for my intakes.i was gona use an window a/c form filter,it maybe to thick,i read about useing dryer sheets as filters.anyways,this thread is getting long.if anyone has ideas,im gonaserach more in this forum,on venting
any help would help alot,i used to do heating/a/c refirg install and service.14 years in the field.never learned the design part,thats when i screwed my back up 10 years ago..i wanted to mention all this
)but until i buy a tower lian li case,this is all i got to work with,which is plenty for now,any ideas or point me to a thread,that may help,would be geat,cyas..
