- May 1, 2010
I cannot seem to get the blue bios screen on my Dell Dimension 4600. I just think that my computer is just too old to get it. I guess that the blue bios screen is on other Pc's and not mine! Oh well. Oh by the way, when I turn on my computer I only get F2 which is Setup and F12 which is the boot menu. My bios is completely different then the blue screen bios. But I guess that is all right. But I can still get into my bios by pressing my F2 key at startup. Then I go to my bios selection, but I can't change the frequency or the Ratio I would say of my bios. It is different a little bit on my computer. As for my bios, it has 2 choices to choose from. It says Normal and Compatible. My computer was set to Normal as the default, but is it alright to choose Compatible? I chose this before, but my computer sort of crashed on me. That wasn't good at all. But what I believe is to make the computer run more faster and efficient is by selecting the Compatible option. Is that right or not? I would like to know a little bit more please about this Normal and Compatible option in my bios settings? Okay? Because I really want to use my computer with ease and speed, like when I am using the internet. For example, when I am listening to Real Audio sites that I like, I click on the song that I want to listen to. Then it takes like forever to load up the Real Audio on my Real Player. Then when the music starts playing, I see that the bar is not really loading all the way. This is probably because my computer doesn't have enough ram in it. I also tried using Clock Gen, but it did not work for me at all either. I clicked on Apply Selection, restarted my pc, but I did not notice any speed up changes. That's not good to me at all. But really, I am not even sure on how to use Clockgen at all! So can you give me like the easiest tutorial on how to use it for me? Because I would really appreciate that a lot. So thank you on that note. Also, I just upgraded from my Windows XP Home Edition to Windows Vista Ultimate and I like the look and design of Vista! I decided to upgrade to Vista Ultimate cause I got sick of my boring XP. But when I upgraded to Vista, my ram was still at the same size which is usually about 512 MB of Ram. But I wish I had more ram then that! Well anyway, that's mostly what I want to know from you. So just let me know what Compatible and Normal is for my bios settings. Because I really know to myself that there is a way to change the bios selection in my setup menu somehow. So that's it! Thanks a lot.
