Retired Sticky
All things comes to an end. 8rda.com has closed for good! For more detail, please check the site. I have bought a new Abit NF-S 7 which is more reliable than 8rda or the Epox corporation
Epox 8RD does have PCI lock, it is stated in the 8RDA+ FAQ section on epox.com
Official Response from Epox about Fried GF4
Epox Tech USA issued a caution today on AMDMB Forum about GF4 installation on 8RDA+/8RDA and also they have updated their website FAQ as well.
EP-8RDA/+ FAQ: Use caution when installing long video cards.
These info are gathered from AOA Forum
Damaged GF4 List
Standard Procedure installing your GF4.
Corsair XMS PC3500 and NForce2 chipset Compatibility issue
Epox 8RDA+ High FSB club
Epox 8RDA+ VDD Mod
I follow that thread did that vdd mod, but I didn't solder. I use two SMD Grabbers instead.
The POT
The SMD Grabber
The Pots is 1K ohm from Radio Shack and I set it at 700 ohm which gives me 1.80v for VDD
Active cooling on MOSFET
Twinmos PC3200 256mb & 8RDA+ success
Ways go over 200mhz FSB SYNC.
EPoX Tech said:Use caution when installing long video cards. -
Use extreme caution when installing long video cards, such as Geforce 4 TI4600, to avoid damage to the video card. Install your memory modules before installing the AGP video card. Avoid bending or inserting your video card into the AGP slot at angles and watch that the video card does not contact the white memory clips. Quickly secure the AGP card to the case after inserting into the motherboard.
http://www.epox.com/motherboard/support/faq/8rda-memory-clip.jpg
Source:
FAQ# 479
http://www.epox.com/html/support-article.asp?Article=P43Tk3b41Fv43hH0C1x0B10M0I3O2n1Oz03Z3K
Damaged GF4 List
- Stanley Jobson : Leadtek A250TD - GF4 Ti4400 Rev. A
- Soldier2000 : Leadtek GF4 Ti4400
- Caper : Visiontek GF4 Ti4600 Rev. A
- ramirez : Leadtek GF4 Ti4400 Rev. A
- eliteone : Gainward GF4 Ti4600
- Corn : Gainward GF4 Ti4400
- kuzma : Visiontek GF4 Ti4600 180-10083-0000-A02 Rev. B
- Marvin : MSI GF4 Ti4200 128mb rev A
- rocky500 (2) : Leadtek GF4 Ti4600 x2
- xgman : EVGA GF4 Ti4600
- bradmax57 : Leadtek A250TD GF4 Ti4400
- RacerX1 : MSI GF4 Ti4600 A02 Rev. A
- coolman888 : Albatron GF4 Ti4200 Turbo
- youthemandan (2) : Albatron GF4 Ti4200 Turbo and Chaintech GT-60 GF4 Ti4600
- RacinJason231 (amdmb forum) : Gainward GF4 Ti4600 Goldem Sample
- Use a wrist band. ground yourself. touch the psu.
- Install your RAM first before you install your GF4 (install the card last so prevent you from bending your gf4 when install RAM)
- Install your GF4. Make sure you do not bend the GF4 card or rub off any small tiny capacitor against the dimm clip
- Boot the system and flash the bios with the latest official release 8rda2C10.bin
- If you need to swap out your RAM or move it to a different slot, take out your GF4 card first.
Originally posted by PiLsY
Take a look at your board. Now take a look at the clearance between dimm slot 1's clip and the card. Thats right, about 0.2mms. Now look at whats missing off your GF4.....
Because of the length of the GF4 and the proximity of the dimm socket clip theres a tiny transistor that gets knocked off if you install the card straight. What you have to do is bend the back of the card slightly away from the dimm slot when you put it in so the edge of the dimm clip clears the transistor on the GF4.
The 8RDA isnt killing boards - but the design leaves a lot to be desired. Its kind of hard to explain without my camera handy to take a picture and sho you all, but I had the same thing happen to my friend yesterday. Perfectly working card, installed in the 8RDA+ and it was dead. Tried another board - dead. Examined the card against a known working Ti4600 after I noticed how close it was to the dimm clips and sure enough the transistor had been knocked off it.
Spread this knowledge around please lads or a lot of people are going to be VERY upset over christmas.
Ill say again, all you HAVE to do when installing a GF4 is to bend the back part of the GF4 slightly away from the dimm clips (about 1mm if that) when you plug it in. When its in the transistor is below the dimm clip and not being touched at all. Remember to do the same if you take the card out too btw.
Epox 8RDA+ VDD Mod
The POT
The SMD Grabber
- Corsair PC3500 or Twinmos PC 3200 needed
- CPU Interface set to Optimal
- Active Cooling North Bridge (It does get hot)
- Remove JP1 Jumper which sets 100/133 mhz FSB or 166mhz
- Do the VDD mod to increase VDD to 1.80v (Voltage for North Bridge)
Warning! at least two people fried their mobo with this mod because they go over 2.00v - No Fan connect to CPU fan header on the mobo.
- Set your Memory at relax timing then move up.
- Use Bios version 8rda2c10.bin or 8rda2c31.bin
- Lower your multiplier first then try to move up
- Do not use PCI slot #2 and #6, it shares IRQ with AGP Video Card
- Disable Serial and Parallel Ports if you don't use them.
- Disable onboard Sound if you want to use your own sound card. Make sure you disable the onboard game port and midi port as well.
- If you use WinXP, make sure apply SP1 before install nVidia unversial driver 2.0
- USB Keyboard does not work during Driver Updates.
- AC97 at Post : Disable [disable pc speaker sound send to your speaker]
- Disable AGP Fastwrite to get more 3Dmarks2001se points
- Set AGP frequency = 66mhz
- Back up your HD image using Norton Ghost
- Use Winflash.exe which is in the magic bios install directory to flash your bios. Make sure you are not OC when you flash your bios
- When system OC too much won't even post, hit the reset botton and hold the INSERT key and then hitting the DEL key to get into bios [easier way to clear cmos]
- Come Back to check this sticky for updates
