I guess you wish to OC and have some more fun than ~3.9GHz so better wait for new chips
I made BIOS screenshots for review, only 'advanced tab' took 36 screenshots. There is no description for all of that. Now I'm checking new beta BIOS. What is interesting, I can assign up to 16GB memory to APU ( in previous BIOS max was 2GB ). I will probably post some results with memory at 2666, 3200 and 3600.
Youtube User Tum Apisak has been responsible for a number of leaks and spots, often he was spot on. That said, he posted a screenshot of what seems to be a Ryzen 7 2700X processor in the 3DMark database. If this is a true valid screenshot when compared towards the Ryzen 7 1700X, the base clock is 300 MHz higher and the Turbo reached 4100 MHz.
The screenshot reveals pretty much all we need to know and expect about the 12nm Zen+ update and leaves little else to say. So let's keep things simple and understandable and compare the 2700X towards the 1700X.
Doesn't look too promising for OC overhead this round, either. Bummer.the base clock is 300 MHz higher and the Turbo reached 4100 MHz.
**** me.
https://www.computerbase.de/2018-03/amd-ryzen-7-2700x/
Nearly reposted what Johan45 already did. This seems to be being reposted by various English language sites but above seems to be source. I dunno, 4.2 turbo on 2700X, implies possibly 4400 on 2800X, with an extra OC push are we still on for potential 4.5 GHz on a good sample?
only time will tell. If i had to guess, most of the headroom gained went i to raising the clocks 200-300 mhz and fitting under the same tdp. Ill bet these cant get past their xfr either... but do hope i am wrong.with an extra OC push are we still on for potential 4.5 GHz on a good sample?
