Please Help me with my Build...
This build is going around the 4000+ San Diego...
Now i am from Canada and going to be getting most of these parts from NCIX for a christmas present to myself!
Now i want to OC but i am having a dilemma... either 1gb of quality RAM or 2gb of RAM?
Heres the list ive compiled...
ASPIRE X-PLORER CASE FAN WINDOW TEMP. DISP. SILVER-BLACK
AMD Athlon 64 4000+ Processor S939 San Diego 2.4GHZ 1MB L2 Cache 90NM
EVGA E-GEFORCE 7800GT PCI-E 256MB 256BIT GDDR3 Dual DVI-I HDTV VIVO SLI Ready
DFI LANParty UT NF4 ULTRA-D Motherboard ATX S939 NFORCE4 Ultra DDR 2PCI-E16 SATA RAID Sound LAN 1394
Seagate Barracuda 7200.8 250GB SATA W/ NCQ 7200RPM 8MB 8MS Hard Drive
Best Cooler 80MM Clear Case Fan Ball Bearing W/ Blue Leds 3/4 Pin X2
LG Black 52X24X52 CDRW& 16X DVD Combo INT Eide Atapi OEM W/ CDRW SW Burner
CHAINTECH AV-710 PCI SOUND CARD 7.1 24-BIT OPTICAL
Logitech G15 Gaming Keyboard USB Black Silver LCD Panel Programmable Back Lit Keys
Flexiglow Xraider Gaming Rubber Coated Changing Color Illuminated Status Light Mouse USB/PS2
Hiper Type R 580W ATX12V V2 24/20 Pin Blue Power Supply 120MM Blue LED PCI-E W/ Detachable Cable
Now i need to know between these two which you would get?
OCZ EL Platinum REV.2 (TCCD) PC3200 1GB 2X512MB DDR CL 2-2-2-5 184PIN DIMM Dual Channel Memory Kit
OCZ EL Platinum PC3200 2GB 2X1GB DDR400 CL2-3-2-5 184PIN Pin Dual Channel Memory Kit /W Ramsink
Now i will be running games like Battlefield 2 and FEAR and Quake 4 and i need to know what i should do?
Thanks alot in Advance!
Garrett
Garrett
