- Dec 21, 2000
- Orlando,Fl.
Hi All, I'v had the Glaciator over a week now and noticed that for the most part MBM is saying the fan speed is around 2900rpm,it will go to 5800 or so but won't sustain it long.Is this a bad fan? Or is MBM just not telling me the right reading?I remember the PAL6035 I had never read right either,but i can't believe I got 2 bad fans in a row.The system runs great and haven't had any trouble at all. What do you think?
T-bird [email protected] 1300 137x9.5
KT7A-RAID
from what i'v read about this HS and MBM I'm not sure if posting my temps would matter,they are higher then the PAL but according to the tests done It's much better.
KT7A-RAID
