I am told that the cpu i have which is a barton 2500+ will oc to 3200+ speeds with ease. Well, mine sure doesn't . I increased the FSB from 166 (stock) to 200 and it seemed to boot up fine. Ran winxp for about 2 minutes, and then it rebooted its self. Then it would freeze if I tried to load windows. My cpu temps where not even to normal operating temps so it could not have overheated. Since then, I went back to the stock FSB which runs at 1.8 Ghz
I think the problem is my ram or voltage. My Vcore is stock at 1.6V. I am using pc2700 512mb ram. It used to be detected as DDR 266 but once I switched the BIOS from manual DDR Clock to SPD, it was detected as DDR 333??? Haven't tired overclocking it to 200 since I changed it from manual to SPD. I am thinking about getting a gig of PC3200 ram. Would that work better for OC'ing? Or should I increase my voltage? Thanks for any help.
