96s10 Member Joined Dec 3, 2005 Feb 12, 2013 #1 Just curious as to what's the best bang for the buck card if I was to spend $150 MAX?
A anhikilator Member Joined Jan 4, 2011 Location Miami, FL Feb 12, 2013 #2 I believe your best bet would be a 7770 if you want to stay under budget ($114) or, spend a bit more ($170) and get a 7850.
I Infinite66 Member Joined Jun 27, 2012 Feb 12, 2013 #3 Best bet would be as anhikliator said..7770 overclocks great too. I know m local microcenter recently had a gigabyte 7770 GHz edition for $140.
Knufire Senior Member Joined Feb 17, 2010 Location Manassas, VA Feb 12, 2013 #4 The 650Ti is a good bit more powerful than the 7770 at the $120-130 range. A small step up from that is a 1GB 7850, right around your $150 budget.
azanimefan Member Joined Oct 21, 2012 Location Phoenix, Az Feb 13, 2013 #5 650ti or the 7850... depends if you can get the 7850 for less then $150. if you can, get it, if you can't, get the 650ti
