*shivers*
mobo temp = 19*C
CPU Temp = 40*C RPM 2676
Normally cpu temp is at 3000-3300 rpms at same temp..... my load doesnt go over 44-45 on a hot day
XP 2000+
Volcano 7
80mm intake
80mm exuahst
120mm intake
120mm exhaust
+ ps fan
Asus mobo using asus probe and bios to test temp
using stock heat compound...... dosent seem to make much a difference since its decent..... my buddy has same pc just about with a volcano 7+ using artic silver 3 and 3 120s
its sensor'd....... so the cooler it gets the less the fan works...... eh! i dotn really want to control it because those suckers get HIGH AND WHINY sounding if there high..... are those temps good enough? i know they make AMD standards but for most of u......
mobo temp = 19*C
XP 2000+
Volcano 7
80mm intake
80mm exuahst
120mm intake
120mm exhaust
+ ps fan
